Author Topic: Just found this wideband thermal camera  (Read 2141 times)
Offline Ben321Topic starter
« on: August 26, 2018, 03:38:57 am »
This https://www.ino.ca/en/products/3-14-microns-infrared-camera-microxcam-384i-mlwir/ is an MLWIR imager. That means it covers both medium-wave and long-wave IR bands. It's passband is 3um to 14um. Yet it uses a standard VOx microbolometer array. So I'm wondering, what material is the lens made out of, that allows such a wide passband? It can't be germanium, because that is only good for 7-14nm, and is used with standard LWIR images.
Offline Fraser
Re: Just found this wideband thermal camera
« Reply #1 on: August 26, 2018, 09:14:21 am »
Only the AR coating dictates the Germanium passband beyond its physical characteristics of transmission. Multi band AR coatings have been around for decades. Look at what Inframetrics used to produce.
« Last Edit: August 26, 2018, 09:41:20 am by Fraser »
Offline eKretz
« Reply #2 on: August 26, 2018, 12:16:54 pm »
I was going to say that yesterday but wasn't sure of myself. It has always amazed me how just adding a simple microns thick coating can completely change the transmission to such a degree.
Online RoGeorge
« Reply #3 on: August 26, 2018, 12:50:26 pm »
http://hyperphysics.phy-astr.gsu.edu/hbase/phyopt/antiref.html
Offline eKretz
« Reply #4 on: August 26, 2018, 01:41:14 pm »
Outstanding, thank you.
« Reply #5 on: August 26, 2018, 07:10:16 pm »
So uncoated germanium has about 45% transmission from 1.7um to 25um?
Offline eKretz
« Reply #6 on: August 26, 2018, 08:05:25 pm »
Yup, close. See attached.
« Reply #7 on: August 27, 2018, 04:40:00 am »
Interesting. When AR coatings are applied, that boosts the transmission in certain areas. However, does it also cut the transmission in other areas? Or does it leave it at the ~45% value?
Any idea what the transmission properties of an uncoated silicon window is? I'd be interested to see how that compares to uncoated germanium.
Offline eKretz
« Reply #8 on: August 27, 2018, 05:18:50 am »
From what I gather, multiple coatings of varying thickness can be applied to dial in whatever you'd like. I'm sure it's a trade-off sometimes or every lens would use the exact same recipe.
Silicon transmission graph attached.
