Hello Everyone
I'm from Switzerland so in advance my English isnt perfect.
Now to my problem I was able to purchase a defekt ISI Vision 3 Thermal Camera on ebay.
First I tried to start it with 6V because that's what the old batteries had written on them. It startet for like 2seconds and than shut down. I than open it up to have a look at its insides. I tried starting it a few times than than per coincidence I felt that a tantalum smd capacitor was a little to warm.
Which I than replaced. After that the start up was still wonky, than I found out that with 6.7V I have the most success. After I showed it a friend who knows electronics, he meant I should but a 1000mircoFarads condesator parallel to the 6.7V power input.
And than it finally started and worked surprisingly good.
But now out of now where it started to change between Black Hot / White Hot with the frequency of the chopper wheel. I retraced the analog out back to the Raytheon board on which it also looks the same so the problem isnt in the post processing side. And now im hardstuck I read about 100 posts here searching for a similar problem but its seems i'm one of the first.
Here is a video of its current state.
Start up video:
https://youtu.be/LE_qvKfzUG0More or less clean analog video which ran through an 2003ish Panasonic DVD player and than captured it with my Blackmagic design Intensity Shuttle. Here you can clearly see how it always changing between Black Hot / White hot.
https://youtu.be/XP9HZexhf08Here in this Google Drive are more Pictures from the disassembly:
https://drive.google.com/drive/folders/1dsrjLtpKz_IUvKlWptUCu2EEtvB6rm82?usp=sharingThanks in advance for every input you guys have.
