Greetings everyone! It seems I've made an unexpected foray into the world of thermal imaging. I have disassembled an MSA Evolution 4000 firefighting TIC, and it seems to be in some trouble.
Symptoms include:
1. Inability to power on when LCD display is connected.
2. Power management board power on if LCD display is disconnected, but nobody at home in the thermal imaging module!
3. Power management board microcontroller (8-bit Atmel AT90) is functional and outputs serial debug data.
4. Thermal imaging module does not appear to attempt a power on sequence at all. That means no debug data from candidate pins, no change in power draw, no FPC actuation.
5. Thermal imaging module's power connector appears to be supplied roughly 4.5 V on one rail and 6.78 V on another.
I'm interesting in working this puzzle to its conclusion, but I'm wondering if there are any schematics, diagrams, or manuals that can help me. For one thing, I'm unfamiliar with the required power supply rails for the thermal imaging module, and I don't have much information on the model. According to spec sheets, it's a "Customized BAE Microbolometer" with 320 x 240 resolution. From what I've seen in
this document, a likely candidate is the BAE SCC205.
TIA for any guidance!
