Regarding whether an 80 x 60 pixel camera still has something to offer ….. in my opinion such a camera is definitely better than having to use an IR Thermometer as the pixel size on target is smaller and there is some context to a thermal image. I have tested a 80 x 60 pixel camera on PCB repairs and it is a fact that you do not need a high resolution thermal camera to see that a component or IC is getting hot when it should not. Higher resolution does make it easier to identify exactly which component is generating the heat, but the use of a 80 x 60 pixel camera plus some iPA for evaporation tests is still very effective in my experience. If you already own an 80 x 60 pixel camera, there is no need to upgrade unless finances make such easy. Spending $15 on a ZnSe CO2 laser focus close-up lens for such a camera is not a waste if it makes the camera more useable, possibly avoiding the need to spend more money on an upgrade.
As a side comment,, a long time ago (in thermal imaging history terms) a company called IRISYS made people counting sensors that used a 16 x 16 pixel pyroelectric thermal sensor. That company adapted the technology to produce an affordable thermal camera for Industry. The IRI1001 was born. That camera used a 16 x 16 pixel FPA , the data from which was interpolated up to 128 x 128 pixels ! Now I would be the first to say that the capabilities of such a thermal camera would be severely limited by the very low resolution of ten thermal sensor array, but that camera was better than nothing in many applications where a ‘full fat’ thermal camera could not be afforded and it did serve its owners well until better affordable technology was developed. More recently that same company, IRISYS, developed the VT02 and VT04 “visual thermometers” for FLUKE. The VT02 was basically an updated version of the IRI1001/IRI1002 that used a similar 16 x 16 thermal imaging sensor array with its image data interpolated up to the resolution of the built in display. The thermal image was combined with a visible light image to provide context to the very low resolution thermal image. The VT04 used 32 x 32 pixels and was supposed to be the “advanced” model
Those visual thermometers were effectively a ‘poor man’s’ thermal imager but they were not so cheap ! FLUKE’s mother company ended up buying IRISYS for their advanced people counting technology.
Compared to the FLUKE VT02 and VT04, a humble 80 x 60 pixels thermal imaging camera suddenly looks very appealing !
