Hi guys,
I've got a question that might be interesting. Can you swap the thermal imaging module from a FLIR C5 with one from a FLIR Scout TK? I'm asking because the C5's module is broken, and after switching it with the Scout TK's, the C5 turned on okay, but the measurements are all over the place. Is there another way to replace it, or will it always give wrong numbers?
Thanks!
Cheers,
Markus
