@bebopdk: From what I can see in the 1.1.10 firmware the upgrade is done by copying everything in the Upgrade folder, so I'm afraid you'll have to you optotester's script for that
As far as I can tell: none of the scripts presented so far are working on my plain C200. Mine has Firmware 1.1.10 as to the menu. S/N C20020062533 acquired from "Guide sensmart Store" through Aliexpress on 2021, Nov 18th.
- It does not have UVC
- It does not have the selection between USB camera and disk in the menu
- It shows up with one device (see below) with three interfaces: CDC ACM and MS
- It detects files in folder Upgrade from the SD card and says you have to reboot
Upon Upgrade, in the Upgrade folder a file CalTempConfig.ini is saved.
With the usbdisksettings.sh from opto, no Backup is created, no getty is started. With Upgrade.sh no getty is started. It seems the scripts are just ignored or the getty is just not working. The CDC ACM is visible after booting the C200, but no response on commands.
bernd@debian:~$ sudo lsusb -s 2:15 -v
Bus 002 Device 015: ID 1d6b:0106 Linux Foundation Composite Gadget (ACM + MS)
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 239 Miscellaneous Device
bDeviceSubClass 2
bDeviceProtocol 1 Interface Association
bMaxPacketSize0 64
idVendor 0x1d6b Linux Foundation
idProduct 0x0106
bcdDevice 3.14
iManufacturer 3 Linux 3.14.38-6UL_ga with 2184000.usb
iProduct 4 Composite Gadget (ACM + MS)
iSerial 0
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 0x0062
bNumInterfaces 3
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xc0
Self Powered
MaxPower 2mA
Interface Association:
bLength 8
bDescriptorType 11
bFirstInterface 0
bInterfaceCount 2
bFunctionClass 2 Communications
bFunctionSubClass 2 Abstract (modem)
bFunctionProtocol 1 AT-commands (v.25ter)
iFunction 8 CDC Serial
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 2 Communications
bInterfaceSubClass 2 Abstract (modem)
bInterfaceProtocol 1 AT-commands (v.25ter)
iInterface 6 CDC Abstract Control Model (ACM)
CDC Header:
bcdCDC 1.10
CDC Call Management:
bmCapabilities 0x00
bDataInterface 1
CDC ACM:
bmCapabilities 0x02
line coding and serial state
CDC Union:
bMasterInterface 0
bSlaveInterface 1
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x000a 1x 10 bytes
bInterval 9
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 10 CDC Data
bInterfaceSubClass 0
bInterfaceProtocol 0
iInterface 7 CDC ACM Data
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0200 1x 512 bytes
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x01 EP 1 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 8 Mass Storage
bInterfaceSubClass 6 SCSI
bInterfaceProtocol 80 Bulk-Only
iInterface 1 Mass Storage
bLength 7
bDescriptorType 5
bEndpointAddress 0x83 EP 3 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x02 EP 2 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 1
Device Qualifier (for other device speed):
bLength 10
bDescriptorType 6
bcdUSB 2.00
bDeviceSubClass 2
bMaxPacketSize0 64
can't get debug descriptor: Resource temporarily unavailable
Device Status: 0x0001
Self Powered
