They're sending me a T2S to look at - as far as I can tell trom the website, it's basically the same as the P2 but with an adjustable lens, which should be more convenient.
So did you ever get around to test the T2S and form an opinion about the pros and cons compares to the P2 Pro? It was a really nice review you did of the P2 Pro
![ThumbsUp :-+](https://www.eevblog.com/forum/Smileys/default/icon_smile_thumbsup.gif)
I have a bit of trouble to decide between the T2S+ and the P2 Pro. They are currently very similar in price.
Perceived cons/pros of the P2 Pro:
+ Very small
+ Very large depth of field with fixed focus. (20cm to infinity according to Frasers review)
- Needs fixed macro lens for closer than 20cm inspection
- Fixed macro lens has shallow depth of field at appx 25mm.
- No hard case included
- P2 Pro App is crashy and glitchy according to reviews
Perceived cons/pros of the T2S+:
+ Included hard case
+ Built-in variable focus macro lens capable of focusing to ~1cm according to some reviews on youtube
+ Included pistol grip (not really sure, I want to use it though...)
+ May have slightly better image quality than P2 Pro due to the S0 core?? (according to Fraser - no comparison seen)
- Variable focus lens may have shallower depth of field for more general use >20cm ?? (No info found)
- Slightly chunkier case than the P2 Pro
- Slightly less maximum temperature span than the P2 Pro (450C versus 550C)
- Xtherm app is perhaps even less functional than the P2 Pro app?
Hope someone can enlighten me a bit
![Wink ;)](https://www.eevblog.com/forum/Smileys/default/wink.gif)
