Mine lost half its calibration settings (Corrupted flash memory? set the values to zero). While I was able to roughly recalibrate it back to within "Goood enough for what I need" though trial and error while setting various calibration points, its still nowhere near factory, Thankfully I'm only looking for unusual hotspots on system boards.
Its always Best to avoid adjsting any existing calibrations, Though you now have video backup of the current calibration values. It looks like its more software related in this case. There is a factory reset option in the user menus, Be familar with the menus first, as it will reboot in Chinese language as the factory default setting.
Your calibration menu v2.0.22 is also improved, with -10, 20, 100 Calibration points. Mine only has 10'C and 120'C points with an older v1.2.10 firmware
3 points can make a calibration curve, while two only makes a line of (Offset + Slope).
