To add to this thread on different variants of the ICI FM 640 P...
I snagged one off eBay for ~$300, still a good price IMO for what's inside. It was absolutely caked with dust on the inside of the housing and must've been used for a while or in an industrial setting. It has a variation of the visible camera I've never seen before in teardowns (although noted as being on the original model by radziorr). A HIKVision (DS-2CD7027FWD) camera equipped with electronic focus control.
The core is the
DLD640 and the backpack/core combo is the
Dali-Tech D843NT, which is Dali's own module. I'm hoping that this will provide better implementation possibilities if I can get Dali to provide core documentation, plus it's got a much smaller footprint than the later ICI "Plus" models which had a separate processing board.
The login password is different when connecting via IP 192.168.1.102 than the newer modules noted in this thread. Exact same interface otherwise.
Username:
adminPassword:
adminOne thing I did notice is this whole module gets rather warm, which I'm sure isn't great for image sensitivity. I used another thermal camera to image the Dali module (I recognize the irony) and it seems the Altera Cyclone is the main heat source. It would be interesting to see if I can add some heatsinking or cooling to remove this heat. After several minutes the whole core housing becomes heated. I do have a stirling crycooler at my disposal, the Superlink Hybrid 98, which may call for some experimentation.
