But at "get flash data" there is like hundreds of requests. I'm not sure what is going on there...
me too
If you have a working stream without DLLs that means that you were able to write all necessary usb communication already?
Yes... my core is simple... ignore the first frames with the cal info and use just the usable frames.
each frame has some extra bytes. i guess some info's like device temperature and so on.
here you can have my playground with map Cal (this is similar to the Seek Thermal Core, get a low and hi frame, and calc defect pixel, gain and offset).
i have 2 classes, one for the DLL and one without. I like both ways... the DLL way shows only up to 240 different values (Byte range), but the Temperatures are calibrated.
i hope it helps
Note: i have to remove the i3system_USB_DLL_V2_1.dll (size to big). Put yours in the \bin folder
