But at "get flash data" there is like hundreds of requests. I'm not sure what is going on there...
me too
![Cool 8)](https://www.eevblog.com/forum/Smileys/default/cool.gif)
If you have a working stream without DLLs that means that you were able to write all necessary usb communication already? ![Clapping :clap:](https://www.eevblog.com/forum/Smileys/default/clap.gif)
Yes... my core is simple... ignore the first frames with the cal info and use just the usable frames.
each frame has some extra bytes. i guess some info's like device temperature and so on.
here you can have my playground with map Cal (this is similar to the Seek Thermal Core, get a low and hi frame, and calc defect pixel, gain and offset).
i have 2 classes, one for the DLL and one without. I like both ways... the DLL way shows only up to 240 different values (Byte range), but the Temperatures are calibrated.
i hope it helps
![Azn ^-^](https://www.eevblog.com/forum/Smileys/default/azn.gif)
Note: i have to remove the i3system_USB_DLL_V2_1.dll (size to big). Put yours in the \bin folder
