I'm stuck at crosscompiling sunxi u-boot.
There is a interesting ht-a8 binary file located in the root dir.
In the boot directory are some interesting files:
magic.bin
test_config.bin
test_config.fex
Unfortunally there is no ssh and no nc installed. But since the device has wifi and a webserver, i have copied the files in the webserver folder and grabbed the files using wget.
From what i can see, the ht-a8 file show me interesting data.
The files are crosscompiled with linaro toolchain:
gcc-linaro-arm-linux-gnueabi-2012.03-20120326_linux_Seek.
The device seems to have no SPI flash memory. Maybe the ht-a8 is already the firmware file?
@DavidAlfa @tv84 @pcprogrammer I could use a little support from experienced sunxi-fel mode fighters.
Should i try the linaro toolchain compile u-boot?
I attach the files. Like always, remove the .txt from the files, replace the last underscore with a dot.
