Author Topic: HTI HT-203U 256×192 thermal imager for Android phones  (Read 15145 times)
Offline syddTopic starter
  • Country: hu
« on: November 30, 2023, 06:56:41 pm »
Hi
I just ordered the HTI HT-203U on Ali because it was super cheap (130 USD with some coupons), it seems to have the same InfiRay Tiny1-C 256x192 infrared module as many others (e.g. Infiray P2, Lodestar L2, Mileseey TR256i,..). I've got a few questions about this and similar devices:
  • Has anyone got the same device? What are your experiences?
  • Do these only work with the manufacturer's app? Or can I use something else, e.g. Inifiray's Android app? What is the best app for these?
  • I've seen in several review videos that there is significant amount of stuttering, e.g. the frame freezes for a second every few seconds. Is the reason known? What to do about it?
  • Is anyone interested in something about this device that I could test when it arrives? (around xmas)
thanks!
Offline targitaj
  • Country: ie
Re: HTI HT-203U 256×192 thermal imager for Android phones
« Reply #1 on: January 07, 2024, 12:50:19 pm »
Hello
Have you got this device, I'm searching for something not expencive not for professional use, just to look in my house where I have places with bad thermal insulation.
May be you can write some words about your experiance, may be some video
Thank you
  • Country: hu
« Reply #2 on: January 11, 2024, 08:36:24 pm »
Heres a mini review with some pictures:
Case: Seems to be sturdy, most parts are covered in rubber. On the downside the lens is barely recessed so its prone to scratches (its a fixed lens sadly) and I dont see any screws to take it apart.
App: I have tried it with my old phone that uses Android 9. There is a HTI app in play store that did not work but the app provided via a QR code did. I liked that it did not ask for nasty permissions (just camera I think?) all functionality seems to work except taking photos and videos... it just shows an error saying that it failed to store the picture. Could be because of my ancient Android version? I dont know, havent tested with other phones. For me this is not an issue though, I use it to look at it realtime and making a screenshot works.
App features: OK. Simple, has what I need:
- multiple color schemes.
- can set temperature range, either -20-120C or 120C-550C
- 3 ways to show temperature: show min/max/middle on a line or a rectangle or the whole screen
- Performance is good, fast startup. The live feed stops for like a second every minute or so to re-calibrate the sensor.
- The only thing I really miss is that the color scheme is always relative on what you see, e.g. red always means the highest temp on the picture and its not possible to pin down to a value. This results in a funky, color disco video when   I'd love if I could set that use the actual color scheme for say 15-25C, this is sadly not possible.
Heat imaging quality: Sadly I have nothing to compare it to, but it looks excellent, more than enough for HVAC diagnosis. Video is pretty smooth, the advertised 25FPS and 256x192 resolution is realistic.
Summary: does what it says on the box
Offline meanie2
« Reply #3 on: March 19, 2024, 07:04:01 pm »
so little response. no one like this device?
Offline 5B4APV
  • Country: cy
« Reply #4 on: March 31, 2024, 09:58:56 pm »
I have one, I don't have an Android device though. I tried it today with a friend's phone and it seems to work very well even at long distances, but I don't have anything else to compare it to.
I am trying to get it to work in Linux but I haven't had any luck with that yet. It works fine as a webcam on Windows though.
Offline Demon Xanth
« Reply #5 on: April 01, 2024, 05:03:52 pm »
I have one, it works pretty well. The refresh rate and resolution is good. Definitely a step up, seems like the same thing that a Fluke isee is. I tried to run it with the Fluke app and it almost works. Android picks it up and tries to make it work, but the app gives the same "connect camera" screen as the HT-203 app does with the camera disconnected. Likely just a single string checking for a model number is the only thing making it not work. As noted the app is missing a few key features, namely setting a fixed temperature scale, but otherwise works well.
I've ordered a macro lens and will make up a mount since I use it to troubleshoot PCAs. The other cameras in the shop are a Cat S60 and a BV9800. Compared to those it definitely seems a generation above.
Offline Demon Xanth
« Reply #6 on: April 09, 2024, 08:05:03 pm »
I got a ZnSe lens and a friend did a solid and made up a clip. It does pretty well at looking at close up parts now.
Offline ArcSin
« Reply #7 on: April 27, 2024, 01:09:35 pm »
Anyone has any clue where you could get the Tiny1-C 256x192 infrared module without the rest of the dongle?
I have seen cheap dongles that contain it, but when i try to look for actual module without anything else, the price goes up like it just spotted a spider on a toilet chair.
Offline pauluspaulus
« Reply #8 on: July 02, 2024, 05:19:59 pm »
Is there any slightest chance that you can attach project file (like .stl) of this clip?
Thanks
« Last Edit: July 02, 2024, 05:24:40 pm by pauluspaulus »
Offline Demon Xanth
« Reply #9 on: July 19, 2024, 05:10:20 pm »
Here you go.
The following users thanked this post: microeev, yippeeyo
Offline yippeeyo
« Reply #10 on: July 21, 2024, 06:54:54 pm »
I'm going to have the project printed by a shop - any preference on material eg nylon, abs, pet etc and infill percentage?
« Last Edit: July 21, 2024, 07:39:41 pm by yippeeyo »
Offline Demon Xanth
« Reply #11 on: July 22, 2024, 08:40:07 pm »
We just used PETG because that was what was loaded up. You'll need three of the tabs and one of the frame then we just super glued it together.
The following users thanked this post: yippeeyo
Offline yippeeyo
« Reply #12 on: July 29, 2024, 03:48:38 pm »
Mine has just arrived, after setup I noticed that HT-203U occasionally makes a ticking noise and the image on the app locks up for a split second then operation resumes.
The sound seems mechanical - is this normal?
Offline voltsandjolts
« Reply #13 on: July 29, 2024, 04:13:31 pm »
Yes, it's normal for many (all?) thermal cameras to do that, self calibration thing.
Offline yippeeyo
« Reply #14 on: July 29, 2024, 04:39:10 pm »
 :-+ thanks, I was worrying unnecessarily!
Going to print the macro lens holder shortly - pics to follow!
Offline latenhas
  • Country: pt
« Reply #15 on: August 07, 2024, 12:36:46 pm »
Hi, anyone got another app besides the "official" on working with this thermal camera?
Any way to get images with raw data?
I tried the P2 pro but it doesn't recognise.
