Thank you.
I already tweaked with that for the whole day...
I suspect it's the problem with bias.
Even before update, if you set the lens aperture too high, it will have column noise, and if set too low, time constant will be very long. So I already played with that magic parameter for days...
Now after update, I seems cannot get it right, with best value I can guess, the column noise is still way too high...
