Author Topic: Vevor sc240n; Infiray C200se ; Hit-18. which is recommended  (Read 3304 times)
Offline ipn00ticTopic starter
  • Country: pt
« on: December 11, 2023, 10:42:14 pm »
good afternoon, I have 3 thermal chambers for the price of $235, which are: vevor sc240n; infiray C200se; hit-18 Is this price for either of them a good price? Of the 3, which one do you recommend to use when repairing boards with SMD components? thank you very much.
Offline basecase
Re: Vevor sc240n; Infiray C200se ; Hit-18. which is recommended
« Reply #1 on: December 12, 2023, 04:14:22 am »
Regarding the HT-18, make sure it's the HT-18+ model/the one with 256x192 25Hz and not the older 220×160 9Hz model that you're considering. HTI had the HT-18 around for a few years I think, and they only updated that line of product recently.
Other than that, you will likely need to consider getting 3D printed adapter for ZnSe zoom lenses to view SMD parts up close. I got this type of 20 mm diameter lenses along with this adapter for my HTI-19.
« Last Edit: December 12, 2023, 04:18:01 am by basecase »
The following users thanked this post: horiachirculescu@gmail.co
  • Country: pt
« Reply #2 on: December 12, 2023, 09:56:54 am »
thanks, yes the Hit 18 would be the plus, the C200se already comes from a macro lens kit and it seems that the vevor sc240n looks like a copy of the C200se
Offline JOE 2345
« Reply #3 on: March 12, 2024, 02:30:23 pm »
I think C200 will be better.
Offline JOE 2345
« Reply #4 on: March 22, 2024, 08:35:27 am »
I probably will recommend C200. It is their star product. The price is not very expensive
