Yes, I noticed that the saved images are fully radiometric and contain the full temperature range rather than the limited one shown on the display. As Bill-W commented, it is likely that the firmware was just changed to only show the Fever Scanning range of temperatures and I hoped to modify the firmware to eliminate that restriction on measurement. Sadly Hikvision firmware updates are encrypted so I have not been able to dig into them. With regard to accuracy, I believe much of the accuracy gains come from the use of a better FFC flag as a temperature reference and likely a factory calibration that is targeted at the fever detection temperature range to achieve greatest accuracy. Such a limited range calibration sill locks the Radiance to Temperature unit curve to the values that came out of ten microbolometer ROIC at time of calibration. The accuracy at temperatures higher and lower than that restricted range will still be pretty accurate
I really like the DS-2TP31 camera. It is well built and produces very good images co side ring it’s 160 x 120 pixel resolution. Hikvision chose wiseLy when it came to the lens FOV. From memory, the IFOV is similar to one of my 320 x 240 pixel cameras that are fitted with much wider angle lenses. I have used my camera for PCB thermal imaging and it does benefit from a close up lens and produces good imagery. That said, I recently bought the DS-2TP21B (basically a modified HikMicro M10) for £220. The 21B is also 160 x 120 pixel resolution but it has the advantage of a manual focus lens and large touch screen display
The close focus capability of the 21B lens means I do not need a close up lens for PCB work
The 21B and 31B are well worth considering if found at a good price, as was the case for me and you Nikitasius
I used the DS-2TP21B to diagnose a shorted MLCC in a £5000 rugged laptop this week. It makes life soooo easy
I own a FLIR E40 (upgraded to E60+) but would not hesitate to pick up the 21B, or even the 31B for a PCB repair. As a side note, it is interesting that the 21B allows the display of temperatures outside the fever detection range, yet the 31B does not.
Fraser
