I have been using an HT-301 camera with HTI Image app on an Amazon Fire for a while with no problems, but I can't simultaneously charge the tablet and use the camera since there is only one USB-C port. My supervisor ordered a Chromebook to solve this issue. However, the HTI Image app is not available on the play store for Chromebooks. So I tried installing the app via Linux. Install worked and the app opens, but the camera will not connect with the app. Also installed Thermviewer via Linux, but it crashes every time it's opened. Does anybody have any suggestions on how I should go about this?
