Hello,
I compared the source with Tcam DLL and the Seek device hopefully work now.
(removed some waits during sequence and the IDs read before not between...)
Debug 1.11.0.2 here:
https://drive.google.com/file/d/1znOScy11FUWAq8u-zbgAvum3yC__GmtP/view?usp=sharingThis should give the ability to experiment with the raw mode...
The Raw mode of the Seek don't use the shutter, therefore some pixels can go to ADC clipping. better wait for warmup before.
I want to ask you the favor of teaching me to calibrate the camera, I don't know which one: 2 point cal, plank cal, base.
If you could give me a basic tutorial since I did not understand very well what joe explains on his page:
http://joe-c.de/pages/posts/planck_calibration_209.php
or if someone has a calibration file could share it with me.
I haven't spend more time to explore the seek. This guide for a calibration work for every thermal camera.
Basically you have to collect the information: Raw X means Temperature Y
for this you have to use a object with known Temperature.
Maybe the easiest way is to use my calibration and adjust the offset...
1. look at a object with known temperature and place a spot measurement there
2. go to Calibration->Tab:Planck->Planck Kalibr...oh... this should not be german
![Wink ;)](https://www.eevblog.com/forum/Smileys/default/wink.gif)
3. adjust the "Planck_O" Value until the spot shows the real temperature of your object
4. close planck window
5. go to Calibration->Save Cal file->Save
Now the temperatures should match better. The Seek shift the gain and offset on each shutter... additional they are dependent on seek device temperature.
Does Thermovision_JoeC allow for streaming of the IR Image via MJPEG, RTSP, or similar (i.e. like an IP camera), to enable display of the IR image in another app, such as octoprint (3D printing context)?
Joe-C, are you accepting 'undocumented feature' reports?
Network image stream like MJPG:
is currently not supported, but I want to have it.
I want a "color translation" too, to support any kind of live image from a analog camera using a video grabber.
the plan is to setup a color scale and define min and max and translate all colors from live image to a thermal frame.
Not sure I understand 'undocumented feature' reports correctly... but yes.
if you found something unexpected, tell me.
![Cool 8)](https://www.eevblog.com/forum/Smileys/default/cool.gif)
Window and pane positions:
pane positions are only stored if not maximized. Select ImageBrowser, CameraCommanderFlir and Report will auto maximize on select (can be disabled in Settings window).
Windows position restore let into problems if you move it to another monitor you don't have any more. Therefore the default window startup is used.
I had this problem with a Notebook. The window startup outside of the screen.
WebcamB Window on Webcam A:
aha, yes... I have to remove a entry from language file. The language files rename controls.
But the Webcam form is used twice, just open "MainForm.txt" and remove
frmWebcam WebcamA
frmWebcam WebcamB
after next restart the windows are named correctly. (already done in this debug)
About the error message, thanks for note, I look later at this.
I know it would be better to have a better Documentation or WIKI, but I haven't the time for this extra project.
when my wife walks through our apartment, she always has... "ideas"...
"we need this"... "we should do that"...
BTW: nice Camera attachment. Additional you should think about a heat sink at the Seek for better thermal stabilization.
I used a LED lamp with alloy housing and attach a seek and a webcam there.
Kind regards
Joe-c
