Releasing now Version 1.4.4.2Changes:
-Flir Planck Values are saved on closing application
(each time a Flir *.jpg was loaded, the values was overwritten. This values will be used to read Sequence files.)
-DIY Thermocam descriptions are now in sub folder
-Visual effects are now located in "Visual->Effects"
-Visual Gray effect is now available (additional to Visual Relief)
(Visual Gray result a grayscale Visual field, with better contrast to the color scale)
-Visual Isoterm now starts with a opacity
(no more hard borders between IR and VIS)
-Spot Measurement has now a 3x3 Kernel option
(if enabled, the result value is the mean of the point value and the surrounding pixels)
-Spot Measurement has now a show Raw option
(if enabled, the raw value was shown below the temperature... useful for calibration)
-Planck Calibration is now usable for Seek Thermal
-Plot multi (previously called "all Side by Side") files can be loaded again
-Plot Marker
(now 3 Marker pairs are usable. each Marker has 2 Points and calculate the difference between both)
WDC (Warmup Drift Correction) it's a sub function of the "Planck Cal" Window. this use a table to corrects the temperature drift of the camera.
after reading the table, a smoothed curve was used to generate a internal offset table. this offset table was used to correct the Raw value before the temperature was calculated.
the goal is let the cold camera deliver right temperatures.
the wdc file just contains the raw reference value at fist line, followed by pairs of device raw temperature an image raw average value.
To record a new WDC File just point the camera to a uniform heated and temperature stable object. i use the Wall. then enable the camera streaming and the WDC Acquisition from Planck Cal-> Warmup Drift correction.
Wait until the camera is warm.
after save the file, change the raw reference default value to a raw value from the camera if warmup is done.
Flir Sequence (*.seq)will now calculated with the Planck Values (was shared from Flir image grabber). before anybody open a sequence, fist load a image from this camera to get the Planck Values from the camera to calculate the temperatures right (not for old Exx Series... more info below).
Additional some extra settings like offset and resolution was now set automatically.
I know 2 types of Sequence...
1 with one Header (old cameras like i3-i7 or E30-E60)
2 with 2 types of header (newer Cameras like C2, E4-E8)
now it is possible to record a Sequence with self set parameters. this sequence could be downloaded an read by the Thermal sequence function. each frame can be normally analyzed.
RTF Reportit's only a RTF Editor like Windows WordPad. It has not much functionality, but I guess it's enough for a report.
Functions:
- bold, italic, underline
- incase or decease the font size
- text direction (left, center, right)
- bullet markers
- change color of text foreground or background (or the whole page)
- insert a picture (IR, Visual or select extern file)
- insert measurement Table
- use Templates
- auto insert with "Tags"
Tags are text markers, they will be interpreted and replaced by the requested contend.
for example: #IR:320x240# will result a MainIR image scaled to 320x240 (if you have another Image ratio or use a Portrait format, this values needs to be modified).
its now easy to auto generate a report... just open a image, right klick on the thermal image and choose "Generate Report" (each time the submenu will be open, the folder with the templates will be explored). If a new template was placed in "ThermoVision_JoeC_V1.4.4.2_relFE\TVisionData\ReportTemplate" it will be selectable on the next right click.
Here are the Project page with some Images:
https://translate.google.de/translate?hl=en&sl=de&tl=en&u=http://joe-c.de/pages/posts/version_1.4.4.2_199.phpSadly there is a problem with "false Positives" on a virus scanner. but older version, (was previously scanned as clean) has now false positives too. I hope the next Scanner update will fix this.
for now there will be shown 2 false positives:
Gen: Variant.Strictor.131700
Trojan.Strictor.D20274ä
Additional note for Exx users (old model without MSX, maybe the new too). i get this camera a few days ago and note, that no Planck values was stored inside the Images. In this case use the "Device: FLIR Ex" Function and connect to the Camera over Network (Wifi or USB RNDIS). with "init Grab"
all Planck values was read.
I see, that the camera has 2 different Sets of Planck values... one for -20 to 120 °C and one for 0 to 650°C
if somebody has problems or questions, let me know.
Joe-c
