Why Thermal Expert uses two maps? What's the point of this?
Especially regarding such a big difference in measurements between the maps...
Is it possible to display a bit map, but for the measurements use temperature map?
I don't know why.
And no, there is currently no way to use the Byte Map for display and the Temperature Map for Measure.
Internally a Float map stores the Temperatures. From this map the image was build and the Measurements.
So you can see, what you measure.
Very interesting. No distortion on your version of the heat map.
Do you have any idea why this is happening?
well... I read each line from CSV as image line.
I use that way and hope, other Versions and Resolutions from i3 will work too.
But after viewing your CSV I see, I have to improve the my image acquisition, because the last values are truncated.
spitted values are counted 2 times... this cause a pixel shift and if the image resolution was reached, the acquisition stops and ignore the last values.
Maybe they have only a maximal number of chars in there rows.
The few images I get from my Camera don't shows the Issue, maybe I had just luck... or miss fortune because I don't see this before.
![Shocked :o](https://www.eevblog.com/forum/Smileys/default/shocked.gif)
Anyway, I know this Issue and will fix it next time.
thank you guys.
Joe-c
Edit:
If you want to compare the 2 Image frames, you should uncheck Menu->Options->"Use Settings from File".
I tried. Nothing changed.
You mean, the image Changed, but not the Measurements?
sounds good.
Or did you mean something other?
