Release Version 1.7.0.0
Download:
https://goo.gl/VSPc6aChanges:
-Interpolation and color scale are now set in the bar at the bottom.
(previously at function-> display, at the bottom right the current IR resolution is always visible)
-Median implementation
-new color palette "RedGrayBlue"
-Option: "IR page lock" at Visual
(adjusts the height or width when the image size of the IR overlay has been changed with the mouse so that the aspect ratios remain the same)
-About window now has a list view, instead of single-clicks from before.
-The delta line and the measuring line can now also run backwards
-Mbox now has 8 ways change the Size
(before it was 2. When the mouse pointer comes against one of the Mbox walls, the boundaries will change yellow, which will change with a mouse click and move, Default are 10 pixels, this could be changed in Settings->App page)
-IR Zoombox is now no longer at Visual but now in functions tab
New window: PictureProcessingThe window is currently only called with "Visual" and replaces the functions "Visual Rotate" and "Grayscale".
There are also functions for changing the size, adjusting brightness and contrast as well as the color balance and crop.
This makes it easier to edit visual image than extract them, edit them externally, and import them again.
Graph HistogramThis new type is a relative histogram which, depending on the scale, indicates the frequency of certain temperatures, as was already possible in the case of the previous one. But this time it is a bar graph to which the current color scale is applied. In addition, there is a cursor line, which displays 3 values: the counted temperature, its frequency and the cursor index. As with the old histogram, it is only calculated and displayed when the window is activated.
In the case of auto scaling, the highest occurrence determines the height scale. If manually, you can use the number on the right to set the height scale itself, which is simply not shown.
reportFrom now on, existing reports are not just overwritten.
Now a you will be asked by new content to add or replace.
There are 2 new templates for adding single pages. In addition, reports can now be started from the imagebrowser with all the selected images.
Serial SensorFrom now, a setup can be saved and loaded. There are 2 setups that are automatically loaded (e.g., "TVisionData\SerSens_Setups\Autoload_SerialSensor1.txt").
In addition, the protocol for the OWON B35 multimeter (
https://www.eevblog.com/forum/testgear/need-advise-for-owon-multimeter/) is now supported. It is thus also possible to record voltages, currents, resistances or other parameters in addition to the regular thermal image temperatures.
Since a "Serial Sensor" can also be used as an input for the "TempSwitch", it is also possible to trigger by voltage or current limits.
![DMM :-DMM](https://www.eevblog.com/forum/Smileys/default/smiliey_dmm.gif)
The name of the active sensor corresponds to the selected measurement type.
best wishes
joe-c
