Thermal imaging ...... thermal cameras..... and now for something completely different.....
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
Many who read the words "thermal imaging" will understandably think of thermal cameras that produce an image of the thermal scene, with varying levels of resolution depending upon capabilities of the hardware. Well this post introduces a different sort of thermal 'imager' ...... the Raytek (FLUKE) RAYMMLTSSF2V stand-off thermometer with video output !
OK, so lets talk about these thermal sensors used in industry.
In many applications there is a need to closely monitor the temperature of surfaces or equipment as part of preventative maintenance or process monitoring. It is possible to use modern thermal cameras for such tasks but is that the most appropriate tool for the job, especially for long term monitoring in potentially hostile environments? Such environments can include explosive gases or high ambient temperatures. The answer is simple ... use the appropriate tool for the job and maintain the KISS principle where able.
So what IR thermometers are found in such applications ? Some may think IR thermometers are handheld devices or 'old tech' .... if so, think again. IR thermometers come in many forms and they range from simple to sophisticated in terms of capabilities. The simplest forms are a suitable sensor + optics head that connects to a thermocouple input on a digital thermometer. No power is needed for these passive heads. Next is the IR thermometer head that includes electronics to provide either a digital or analogue output to a logging or display device. Such IR thermometers often incorporate sophisticated Germanium optics that can not only provide an excellent thermal scene capture, but also a visible scene as well. Co-axial lens designs provide the thermal energy that the sensor requires plus a normal visible light lens assembly is incorporated to provide a telescope function for aiming the head at the target of interest. The visible light lens sits in the middle of the large germanium lens. An expensive assembly ! Where optical aiming is not appropriate or needed, laser aiming is also an option. This can involve a laser built into the co-axial lens assembly or a self contained laser alignment tool that screws onto the front of the head for aiming only and is then removed for the heads normal operation. So there you have the choice of observing the target using the human eye through a cross hair telescope or by direct observation of a laser dot on the target surface.
Now to introduce the Raytek RAYMMLTSSF2V head. This is a little different to the heads detailed above. It is a self contained IR thermometer that provides digital temperature readout on an integral LCD display and to monitoring equipment or a PC via a data link. This 'intelligent' head contains many setup options to suit the application in which it is deployed. A local navigation D pad provides access to the setup menus but the head is remote controllable as well. What makes this head a little different to the normal run-of-the-mill heads is its aiming system. The head uses a large Germanium/glass co-axial lens assembly. The central visible light lens assembly provides scene imaging to both a optical eyepiece and a digital camera within the head. Yes this measuring head contains a digital camera
The option of aiming the head via a simple eyepiece with cross hairs or a video camera provides the user with many options when it comes to deployment and monitoring.
When connected to a PC, the measuring head provides the user with instant temperature, logged temperature over time in graph form and the image from the digital aiming and monitoring camera within the head.
So is the head a "Thermal Imager" ? Well it contains a visible light aiming camera that incorporates a targeting cross hair. The head is aimed at the required target and the surface temperature is measured.... so yes it is a form of thermal imaging
For those wondering, yes these industrial IR thermometers are very expensive. They are designed to be rugged and effective in their intended use. They can be far more appropriate than deploying a thermal camera in the same scenario. The large Germanium lens assembly can be just as expensive as that found in thermal cameras and can be even more complex due to the co-axial aiming optics incorporated within them.
I decided to write about these measurement heads as some applications may actually benefit from using such instead of a thermal camera. I own several Raytek and AGEMA (Raytek) industrial IR thermometer systems.
Fraser
