Author Topic: (SOLVED)Image intensifier tube with CCD; Can we identify it and find it's specs?  (Read 1065 times)
Offline ZaproTopic starter
  • Breaking stuff to go fix it again
Hi. I wrote a wall of text here but the image uploader decided to delete it  |O
Any help identifying this tube? Google doesn't give many hits.
Can i power this from 3V safely?
Thanks in advance.
// Per.
« Last Edit: March 22, 2021, 01:51:34 pm by Zapro »
Online Fraser
This IIT is from the Millard/Philips XX1500 range. Commonly found in medical imaging systems. You cannot find a datasheet for the XX1550 because it is a custom order from an OEM but the 1500 series specs should suffice. Exceeding an IIT’s maximum voltage is unwise and can lead to inverter failure. Personally I would run the IIT at the stated nominal 2.7V using a suitable regulator circuit. I would not use a 3V3 regulator as that is too close to the maximum permitted voltage. You could use a 3V3 regulator with a silicon diode in series with its output though  ;)
Datasheet is here....
https://frank.pocnet.net/other/Mullard/Mullard_NightVision_XX1500_1980.pdf
Safe supply range is 2.0V to 3.4V. Do not exceed 3.4V !
Fraser
« Last Edit: March 21, 2021, 10:49:05 am by Fraser »
The following users thanked this post: Zapro
Thank you, Fraser!
I managed to heat up the fibreoptic bundle and free it from the CCD. It's only held on with epoxy on the edge and oil on the optical surface.
If i get to the point of attaching this to another CCD, any tips on what kind of oil that is suitable - will standard mineral oil do?
If the new CCD ends up being smaller size, i wonder if i can machine the fibreoptic piece smaller on my CNC milling machine. I guess i need some diamond tools and patience :)
// Per.
Online Fraser
Not my speciality. That is a question that may get an answer on the main forum as there are lots of optics experts there.
Fraser
