Author Topic: HIKMICRO B10 Wide Angle Lens / Macro Lens  (Read 2105 times)
Offline saladoilTopic starter
« on: November 15, 2023, 03:19:25 pm »
Hi there!
I'm about to buy a Hikmikro B10 and i wonder if I could make a diy wide angle lens for it.
There are solutions for a znse macro lens with a printed mount. Is there a way to build a wide angle lens? Any suggestions?
For the macro lens: which focal length and diameter are best suitable?
Thank you for your support!
Offline RogerG
Re: HIKMICRO B10 Wide Angle Lens / Macro Lens
« Reply #1 on: September 06, 2024, 11:14:48 am »
quite old topic, but it's interesting for me, too  8).
The original lens from Hikmicro has a focal length of 4.6mm. I wasn't able to find a third party lens in this range so far. Someone here in this board took a lens with a focal length of 50.8mm and 20mm diameter and had success in his self printed adapter. These lenses are easy to find at Ebay for a reasonable price.
https://www.eevblog.com/forum/thermal-imaging/hikmicro-b20/msg4098034/#msg4098034
Did you find your own solution since yout first post?
The original HM-B201-MACRO lens has a bit stiff price tag (100€) compared to the one by UNI-T (40€).
Regards
Roger
