Hi!
I'm in possession of 640x512 30Hz Tau 2 core (from my mechanically damaged DJI XT camera/gimbal) and would like to use it as i.eg. USB camera in other project. Initial idea was to purchase Flir VPC module for it, but then I discovered that you take analog video signal directly from 50-pin hirose connector (the white on on the back of the camera), so purchasing this VPC module would be a waste of money.
Ok, just add some CVBS to USB video grabber to it and mission complete, but then I came across Tau 2 Electrical Interface Description Document (attached) which explains digital (CMOS and LVDS) video formats that camera can spit out.
I was struggling to find any LVDS interface, but there is plenty of CMOS->USB modules on the market - like those that you can pair with i.eg. OV2640 CMOS cameras.
Have anybody of you ever tried to grab digital signal instead of analog one from Tau 2?
Would the digital video transmission benefit in any way an image quality?
