I am Vincent. I recently get a PM695 that was pretend to be dead. As a matter of fact, the battery was dead and the camera is perfectly fine!
But after use, I noticed that the NiMh battery came only last an hour which is short time. I look up for batteries on Internet but 150$ for a battery is very expensive
. I paid 20$ to repairing mine.
I tried something else. I did buy the connector for the output plug and I hooked up a LiPo battery on it. I worked fine but I used a 3s battery with a voltage of 12,6V max with a nominal voltage of 11,1V. As you may noticed the camera switch itself off when it is powered under 12V to 13V. I was able to get 45min of power out of a 3300mAh that I cannot fully discharged.
So my plan is to rebuild a new baterry cas with a 3D printer and then put inside a 4S 14,8V LiPo 4500mAh battery in order to extend my time of use. With 2 or 3 battery of that type, I think that I should be able to last one full day of experimentation.
After some use, I think that this camera is pretty good and It is worth to put some time in it to get the maximum of it.
I hope that the info that I put in my message will help other guys and feel free to comment. I am intresting in any suggestions.
Best regards,
Vincent
