Time for some commentary on the design of the PM570........
AGEMA/FLIR PM570 camera Circa 1997
The Outer CasingThe cameras casing is made from Aluminium and is of the "Palmcorder" format, though somewhat larger and heavier than a camcorder of the period. For a thermal camera of the 1990's, the PM570 was actually quite compact and is very well constructed. Parts of the casing interior show the signs of having been milled out. A sign of a quality casing. The casing would have been an expensive component to manufacture but it projected the desirable image of a solid professional thermal imaging system that would survive in the Industrial environments for which it was intended. The "PM" prefix in its model ID means "Preventative Maintenance" and this is an area of Industry that makes good use of the capabilities offered by a thermal imaging system.
The aluminium of the casing is coated with a very hard wearing textured paint that may be some form of enamel. The paint does not scratch or come away from the aluminium easily and the cameras are often in good cosmetic condition, even after years of hard use in less than friendly working environments. Such environments include heavy industry, Oil platforms and mines. These cameras from the 1990's and early 2000's are built like Battleships and able to take a pounding. Modern cameras are built ore like a Navy Corvette and need a little more care in their handling
Access to the cameras Battery bay and PCMCIA memory card slot is via a latched metal door that incorporates a weather seal around its perimeter. With the door open, the cameras main PCB can be seen and the camera is vulnerable to dirt and debris infiltration.
On the top of the camera there is a colour LCD electronic viewfinder, external monitor mounting plate and the user keypad. The unit is equipped with a hand grip on the right hand side, with the power button and joystick positioned for easy operation with the thumb. The Joystick is used to navigate the various drop down menus, motorized focus and continuous eZoom functions.
