EDIT:
Get clutch version 1.4.7 or higher! the lower one doesnt seem to workNot for the faint hearted!
I dont want to upload a cracked file, so you guys can have a bit of fun and learn in the process of having fun.
Also i should propably say that its up to you what you do with your modified files (as in keep it legal) and you do this at your own risk
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
Let me know if it did or didnt work.
The images help with the txt step by step instruction i wrote the past two hours.
Something i want to know while someone trys this.
If you open the decrypted Rosebud in the hex editor please go to Analysis -> Checksums and run MD-5
before editing the file!This gives a checksum at the bottom: It should be F16037A3DBE0E8D4C2A7900F3BC204DC
Else i have something to work out and this might not work. I tried this with my original clutched ipa file and the Rosebud i end up with works perfectly
Also i want to give a shoutout to Jenkins, who seems to have made the app (seems to be the username of the MAC that was used) Great app now give us all the things that are hidden in there
![Tongue :P](https://www.eevblog.com/forum/Smileys/default/tongue.gif)
