if you simple delete the SuperResDenoise.plist nothing changes ![Sad :(](https://www.eevblog.com/forum/Smileys/default/sad.gif)
I think devilmastah can better look inside the code of the flir one app
i had a little play with the SuperResDenoise,plist.
First of all, the app seems to be perfectly fine with missing that file (as i delete it the app still works).
Furthermore weird, there seems to be a reference to the file in the code so i dont really get why it doesnt just crash.
Then, it does something with the values of it and puty them in a function Write_4x4x8_PSD.
i am pretty shure i have seen a file or reference to 4x4x8 psd somewhere but cant find it right now.
Now the nice thing, i removed the file and made some pictures, see the attatchment, right onces are without the file!
Left ones with. One of them is a shot accross my bed to the window (i should fix the isolation of that), and the other one is a uniform tabletop with the camera directly on it.
Both images have the normal picture removed with flir tools.
The sharpness of the ir image itself does not seem to be really affected as in its not burryer, looks more crisp overall.
I archieved this by doing the following.
1. I chmodded the file via ssh terminal to 777, "chmod 777 SuperResDenoise.plist"
2. After that you are able to rename or delete it, if you dont own or have rights to the file the file will not get delted or modified!
3. Then i rebooted the app, make shure its not running in the background (double click home button)! Thats really important as the file wil be in memory when the app is in background, hence you see no change.
tip, im not shure if this is needed, i already own all the files as root. You could chown the file to root. I dont think its needed.
EDIT 1:As to the
from the Flir Ex / Exx we know the switch:
rset .image.flow.digitalFilter.noiseGen.enabled true/false
rset .image.flow.digitalFilter.noiseGen.level 150 (mK)
values, the enable disable does seem to live in camerafiles/system/calib.rsc - however i did not notice any change (maybe thats due to the lack of my SuperResDenoise).
Another thing i noticed is their reference:
"## NO VALUES READ FROM .calib.detector. ATM. Everything is set in ifc_detector_dummy.cpp in appcore." that is on line 175 for me.
*goes back at decomping app*
EDIT 2i found some references to toggle MSX mode and other stuff, i will now boot my mac to take a look at the other screensets that are in the app
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
Maybe those are some future items they want to include, but would be nice to have them now
