Hi there,
Did a search but most reviews seem to compare the non-pro versions. I need a thermal camera for looking at possible high dissipation on pcb components, so tends to be fairly close up work - around 30-50cm. I know the Seek has a manual focus and higher res but the Flir has MSX which could be pretty important in identifying components but can the autofocus on the Flir focus well at this distance?
Any advice you can give would be most appreciated.
