Author Topic: Flir One Pro Optical Parallax  (Read 2374 times)
Offline massterTopic starter
« on: March 31, 2024, 03:22:13 am »
Hi
This cheap thermal imaging device has 2 cameras: one for the visible spectrum and one for the infrared spectrum. Given there is a distance between them, a parallax error exists.
Do you know the minimal distance from a target PCB that will allow a fairly precise hot spot localisation?
« Last Edit: March 31, 2024, 07:17:42 am by masster »
