It uses the MC68340 ! ..... my old friend from the Thermovision PM series
That processor board is called the “LiCo” in the PM series cameras and I immediately recognised the AGEMA hand in the “RiCo” board design
In the PM series that board is the heart of the camera that is connected to another large PCB that has its own processor board and deals with the output of the microbolometer. Your camera design is somewhat different however. I will need to study the pictures some more and try to make sense of them. Parts of the RiCo PCB look familiar, others not. I think I can recognise the video encoder stage as it looks similar to the PM695 LiCo that uses a FPGA in place of the dedicated BT series video encoder IC that went obsolete.
Can you check to see if any of the Photon ‘stack’ PCB’s are fitted behind the Microbolometer ? I am hoping that you will find all but the power PCB mounted on the photon and that FLIR are feeding the cameras digital output to the PCB that you have shown on the end of the FPC.
The camera will clearly comprise of some core elements that should not be hard to identify. I have made a list that draws on my knowledge of the AGEMA Thermovision PM series.
1. Power supply PCB with main power rails created for board set. Some power rails may be further processed locally on other PCB’s
2. Main processor PCB that controls the camera and possibly provides the auto focus function.Any video output often comes from this PCB.
3. Interface PCB between the microbolometer and LiCo PCB. This PCB can be a dedicated processing stage with its processed output being fed to the LiCo for use.
4. Communications interfaces. There is usually a Serial interface on the LiCo but other interface options may have their own dedicated PCB’s that feed into the LiCo.
5. Servo PCB. Where a camera has additional functionality such as auto focus and Zoom functions, there can be a dedicated servo driver board that is either ‘dumb’ or contains processing for the focus element position as part of an auto focus feedback loop. Heavy current drivers can be included on this board where larger servos are being used.
6. Display PCB.Where required a local display screen or EVF can be integrated into ten design. This is usually connected to the LiCO PCB that contains ten video encoder. Available video types include composite and S-Video but composite is often used for a EVF.
7. Battery power. where there is a need for battery power here will often be a dedicated Battery PCB that deals with the needs of the battery pack and connects to the main Power supply PCB.
Fraser
