// stream until key is pressed.
char c;
read(0, &c, 1);
/* End the stream. Blocks until last callback is serviced */
uvc_stop_streaming(devh);
puts("Done streaming.");
gcc -o flirfox2 flirfox2.c -luvc -lm `pkg-config --cflags --libs opencv`
So this pretty much completes a Proof of Concept and now the actual pixel temperature can be calculated and displayed, you will find my comments in the code. I recall you were the one who reverse engineered FLIR temperature calculation? This at the moment is beyond my ability so pls see if you can update the code with it.
Atmospheric Temperature : 20.0 C
Atmospheric Trans Alpha 1 : 0.006569
Atmospheric Trans Alpha 2 : 0.012620
Atmospheric Trans Beta 1 : -0.002276
Atmospheric Trans Beta 2 : -0.006670
Atmospheric Trans X : 1.900000
Planck R1 : 15314.136
Planck B : 1404.6
Planck F : 1
Planck O : -978
Planck R2 : 0.011565135
Object Distance : 1.00 m
Emissivity : 0.60
Reflected Apparent Temperature : 20.0 C
Relative Humidity : 50.0 %
What do you mean with this code snippset from fuchsjagd?
It's like a 20x20 pixel watermark.
You can see it in your video at the bottom on the left side.Code: [Select]unsigned short *pix = frame->data;
int x, y;
for (y = 160; y < 180; ++y) {
for (x = 60; x < 80; ++x) {
pix[y * 320 + x] = pix[y * 320 + 60];
root@iJudge:/home/pantheron/libuvc# build/flir e4x.raw
UVC initialized
Device found
unsupported descriptor subtype: 3
unsupported descriptor subtype: 13
Device opened
DEVICE CONFIGURATION (05ac:8510/CC2CAV0DA1DN9KE0) ---
Status: idle
VideoControl:
bcdUVC: 0x0100
VideoStreaming(1):
bEndpointAddress: 130
Formats:
UncompressedFormat(1)
bits per pixel: 16
GUID: 5955593200001000800000aa00389b71 (YUY2)
default frame: 5
aspect ratio: 0x0
interlace flags: 00
copy protect: 00
FrameDescriptor(1)
capabilities: 00
bit rate: 24576000-147456000
max frame size: 38400
default interval: 1/29
interval[0]: 1/29
interval[1]: 1/25
interval[2]: 1/23
interval[3]: 1/14
FrameDescriptor(2)
capabilities: 00
max frame size: 50688
interval[0]: 1/29
interval[1]: 1/25
interval[2]: 1/23
interval[3]: 1/14
FrameDescriptor(3)
capabilities: 00
max frame size: 153600
interval[0]: 1/29
interval[1]: 1/25
interval[2]: 1/23
interval[3]: 1/14
FrameDescriptor(4)
capabilities: 00
max frame size: 202752
interval[0]: 1/29
interval[1]: 1/25
interval[2]: 1/23
interval[3]: 1/14
FrameDescriptor(5)
capabilities: 00
max frame size: 614400
interval[0]: 1/29
interval[1]: 1/25
interval[2]: 1/23
interval[3]: 1/14
FrameDescriptor(6)
capabilities: 00
max frame size: 345600
interval[0]: 1/29
interval[1]: 1/25
interval[2]: 1/23
interval[3]: 1/14
FrameDescriptor(7)
capabilities: 00
max frame size: 1843200
default interval: 1/10
interval[0]: 1/10
MJPEGFormat(2)
bits per pixel: 0
GUID: 4d4a5047000000000000000000000000 (MJPG)
default frame: 2
aspect ratio: 0x0
interlace flags: 00
copy protect: 00
FrameDescriptor(1)
capabilities: 00
max frame size: 1044480
interval[0]: 1/29
interval[1]: 1/25
interval[2]: 1/23
interval[3]: 1/14
FrameDescriptor(2)
capabilities: 00
max frame size: 1179648
interval[0]: 1/29
interval[1]: 1/25
interval[2]: 1/23
interval[3]: 1/14
FrameDescriptor(3)
capabilities: 00
interval[0]: 1/29
interval[1]: 1/25
interval[2]: 1/23
interval[3]: 1/14
END DEVICE CONFIGURATION
bmHint: af90
bFormatIndex: 5
bFrameIndex: 157
dwFrameInterval: 32766
wKeyFrameRate: 0
wPFrameRate: 0
wCompQuality: 0
wCompWindowSize: 0
wDelay: 4176
dwMaxVideoFrameSize: 0
dwMaxPayloadTransferSize: 4197312
bInterfaceNumber: 254
get_mode: Invalid mode (-51)
Device closed
UVC exited
Good point. Can you post the changed code line , thks.
res = uvc_find_device(
ctx, &dev,
0, 0, NULL);
exiftool -Atmos* -Planck* -Object* -Emis* -Reflected* -Relativ* FLIR_sample.jpg >e4data.txt
$ exiftool -Atmos* -Planck* -Object* -Emis* -Reflected* -Relativ* FLIR3344.jpg >e4data.txt
$ cat e4data.txt
Planck R1 : 13061.76
Planck B : 1352.2
Planck F : 2.7
Planck O : -7334
Planck R2 : 0.027282318
Emissivity : 0.95
$ /usr/bin/cc -o flirfox6 flirfox6.c -luvc `pkg-config --cflags --libs opencv` -lm
$ sudo ./flirfox6
//check
$ port installed | grep active
cmake @3.3.1_0 (active)
libusb @1.0.19_0 (active)
jpeg @9a_1 (active)
$ git clone https://github.com/ktossell/libuvc
Cloning into 'libuvc'...
remote: Counting objects: 526, done.
remote: Total 526 (delta 0), reused 0 (delta 0), pack-reused 526
Receiving objects: 100% (526/526), 263.90 KiB | 309.00 KiB/s, done.
Resolving deltas: 100% (305/305), done.
Checking connectivity... done.
$ cd libuvc/
// now use patch in the src folder
$ patch < libuvc.patch
patching file stream.c
cd ..
$ mkdir build
$ cd build
$ cmake ..
-- The C compiler identification is AppleClang 5.1.0.5030040
-- The CXX compiler identification is AppleClang 5.1.0.5030040
-- Check for working C compiler: /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cc
-- Check for working C compiler: /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/c++
-- Check for working CXX compiler: /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- No build type selected, default to Release
-- No target type selected, default to shared library
-- Found JPEG: /opt/local/lib/libjpeg.dylib
-- Building libuvc with JPEG support.
-- Configuring done
CMake Warning (dev):
Policy CMP0042 is not set: MACOSX_RPATH is enabled by default. Run "cmake
--help-policy CMP0042" for policy details. Use the cmake_policy command to
set the policy and suppress this warning.
MACOSX_RPATH is not specified for the following targets:
uvc
This warning is for project developers. Use -Wno-dev to suppress it.
-- Generating done
-- Build files have been written to: /Users/jfried/Documents/Flir/uvc/libuvc/build
$ make
Scanning dependencies of target uvc
[ 10%] Building C object CMakeFiles/uvc.dir/src/ctrl.c.o
[ 20%] Building C object CMakeFiles/uvc.dir/src/ctrl-gen.c.o
[ 30%] Building C object CMakeFiles/uvc.dir/src/device.c.o
[ 40%] Building C object CMakeFiles/uvc.dir/src/diag.c.o
[ 50%] Building C object CMakeFiles/uvc.dir/src/frame.c.o
[ 60%] Building C object CMakeFiles/uvc.dir/src/init.c.o
[ 70%] Building C object CMakeFiles/uvc.dir/src/stream.c.o
[ 80%] Building C object CMakeFiles/uvc.dir/src/misc.c.o
[ 90%] Building C object CMakeFiles/uvc.dir/src/frame-mjpeg.c.o
[100%] Linking C shared library libuvc.dylib
[100%] Built target uvc
// fast check with my full pathes
$ cc -o flir flir.c -I/opt/local/include/ -I/Users/tomas/Documents/Flir/uvc/libuvc/build/include -I/Users/tomas/Documents/Flir/uvc/libuvc/include/ -L/Users/tomas/Documents/Flir/uvc/libuvc/build -luvc
$ ./flir
UVC initialized
usage: ./flir out.raw
./flir 1
UVC initialized
Device found
Device opened
DEVICE CONFIGURATION (09cb:1007/[none]) ---
Status: idle
VideoControl:
bcdUVC: 0x0100
VideoStreaming(1):
Formats:
bits per pixel: 16
default frame: 1
aspect ratio: 0x0
interlace flags: 00
copy protect: 00
FrameDescriptor(1)
capabilities: 03
bit rate: 912384-912384
default interval: 1/3
interval[0]: 1/15
interval[1]: 1/7
interval[2]: 1/3
bmHint: 0000
bFormatIndex: 1
bFrameIndex: 1
dwFrameInterval: 666666
wKeyFrameRate: 0
wPFrameRate: 0
wCompQuality: 0
wCompWindowSize: 0
wDelay: 1
dwMaxVideoFrameSize: 153600
dwMaxPayloadTransferSize: 157696
bInterfaceNumber: 1
Streaming...
got frame 1441305922:212093, 153600 bytes
got frame 1441305922:308068, 153600 bytes
got frame 1441305922:404825, 153600 bytes
got frame 1441305922:500120, 153600 bytes
got frame 1441305922:594571, 153600 bytes
Planck R1 : 14901.4
Planck B : 1400.9
Planck F : 2.5
Planck O : -7187
Planck R2 : 0.02804
Emissivity : 0.95
great work
unfortunately now I have not enough time to go deeper in your code
$ lsb_release -a
Description: Ubuntu 14.04.1 LTS
$ sudo apt-get install exiftool
Note, selecting 'libimage-exiftool-perl' instead of 'exiftool'
$ sudo apt-get install libimage-exiftool-perl
$ exiftool -ver
9.46
Image-ExifTool-10.01/exiftool -X -Atmos* -Planck* -Object* -Emis* -Reflected* -Relativ* FLIR3344.jpg
<?xml version='1.0' encoding='UTF-8'?>
<rdf:RDF xmlns:rdf='http://www.w3.org/1999/02/22-rdf-syntax-ns#'>
<rdf:Description rdf:about='FLIR3344.jpg'
xmlns:et='http://ns.exiftool.ca/1.0/' et:toolkit='Image::ExifTool 10.01'
xmlns:FLIR='http://ns.exiftool.ca/APP1/FLIR/1.0/'>
<FLIR:AtmosphericTemperature>20.0 C</FLIR:AtmosphericTemperature>
<FLIR:AtmosphericTransAlpha1>0.006569</FLIR:AtmosphericTransAlpha1>
<FLIR:AtmosphericTransAlpha2>0.012620</FLIR:AtmosphericTransAlpha2>
<FLIR:AtmosphericTransBeta1>-0.002276</FLIR:AtmosphericTransBeta1>
<FLIR:AtmosphericTransBeta2>-0.006670</FLIR:AtmosphericTransBeta2>
<FLIR:AtmosphericTransX>1.900000</FLIR:AtmosphericTransX>
<FLIR:PlanckR1>18453.355</FLIR:PlanckR1>
<FLIR:PlanckB>1460.6</FLIR:PlanckB>
<FLIR:PlanckF>1</FLIR:PlanckF>
<FLIR:PlanckO>-7003</FLIR:PlanckO>
<FLIR:PlanckR2>0.013993904</FLIR:PlanckR2>
<FLIR:ObjectDistance>1.00 m</FLIR:ObjectDistance>
<FLIR:Emissivity>0.95</FLIR:Emissivity>
<FLIR:ReflectedApparentTemperature>20.0 C</FLIR:ReflectedApparentTemperature>
<FLIR:RelativeHumidity>50.0 %</FLIR:RelativeHumidity>
</rdf:Description>
</rdf:RDF>
185: sprintf(szText, "%3.1f C / RAW: %i",t, pix[cpY * 320 + cpX]);
The temperature differences under crosshair I can't explain with averaging of 2x2 or 3x3 pixels on the E4 display // export with Flir Tools the temperature of all Pixels (Flir Tools export as *.csv)
$ head -n11 FLIR0080.csv
File: ;C:\Users\admin\Desktop\1\FLIR0080.jpg
Parameters:;Emissivity:;0,95
;Refl. temp.:;20 °C
;Distance:;1 m
;Atmospheric temp.:;20 °C
;Ext. optics temp.:;20 °C
;Ext. optics trans.:;1
;Relative humidity:;50 %
Frame 1;18,359;18,373;18,373;18,359;18,387;18,429;18,401;18,457;18,457;18,443;18,443;18,429;18,415;18,415;18,401;18,401;18,401;18,387;18,387;18,373;18,359;18,345;18,331
// print a readable form
s jfried$ grep Frame FLIR0080.csv | tr ";" "\n" | head -n 17
Frame 1
18,359
18,373
18,373
18,359
18,387
18,429
18,401
18,457
18,457
18,443
18,443
18,429
18,415
18,415
18,401
18,401
// get Flir parameters for excel sheet
$ /Image-ExifTool-10.01/exiftool -Atmos* -Planck* -Object* -Emis* -Reflected* -Relativ* FLIR0080.jpg
Planck R1 : 15119.786
Planck B : 1405.2
Planck F : 2.5
Planck O : -7652
Planck R2 : 0.027600825
Emissivity : 0.95
// export RAW values of radiometric image
// swap bytes
$ convert -define png:swap-bytes=on FLIR0080.png FLIR0080swap.png
// print RAW values of first 16 Pixel (top left)
$ for i in $(seq 0 15); do convert FLIR0080swap.png -crop 1x1+$i+0 -format "%[fx:round(65535*u.r)]" info:;echo ; done
12167
12168
12168
12167
12169
12172
12170
12174
12174
12173
12173
12172
12171
12171
12170
12170
I will probably stop here for now.
