$ uname -a
Linux ubu64 3.13.0-32-generic #57-Ubuntu SMP Tue Jul 15 03:51:08 UTC 2014 x86_64 x86_64 x86_64 GNU/Linux
$ apt-get install CMake
$ apt --installed list| grep -i usb
libusb-0.1-4/trusty,now 2:0.1.12-23.3ubuntu1 amd64 [installed]
libusb-1.0-0/trusty,now 2:1.0.17-1ubuntu2 amd64 [installed]
$ sudo apt-get update && sudo apt-get install build-essential
$ sudo apt-get install libjpeg-dev
$ sudo apt-get install libusb-1.0-0-dev
$ git clone [url]https://github.com/ktossell/libuvc[/url]
// don't forget to apply the patch from tmbinc in /src/
$ patch < libuvc.patch
patching file stream.c
$ cd libuvc
$ mkdir build
$ cd build
$ cmake ..
-- The C compiler identification is GNU 4.8.4
-- The CXX compiler identification is GNU 4.8.4
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- No build type selected, default to Release
-- No target type selected, default to shared library
-- Building libuvc with JPEG support.
-- Configuring done
-- Generating done
-- Build files have been written to: ../flir/libuvc/build
$ make
Scanning dependencies of target uvc
[ 11%] Building C object CMakeFiles/uvc.dir/src/ctrl.c.o
[ 22%] Building C object CMakeFiles/uvc.dir/src/ctrl-gen.c.o
[ 33%] Building C object CMakeFiles/uvc.dir/src/device.c.o
[ 44%] Building C object CMakeFiles/uvc.dir/src/diag.c.o
[ 55%] Building C object CMakeFiles/uvc.dir/src/frame.c.o
[ 66%] Building C object CMakeFiles/uvc.dir/src/init.c.o
[ 77%] Building C object CMakeFiles/uvc.dir/src/stream.c.o
[ 88%] Building C object CMakeFiles/uvc.dir/src/misc.c.o
[100%] Building C object CMakeFiles/uvc.dir/src/frame-mjpeg.c.o
Linking C shared library libuvc.so
[100%] Built target uvc
$ sudo make install
Install the project...
-- Install configuration: "Release"
-- Installing: /usr/local/lib/libuvc.so
-- Installing: /usr/local/include/libuvc/libuvc.h
-- Installing: /usr/local/include/libuvc/libuvc_config.h
-- Installing: /usr/local/lib/cmake/libuvc/libuvcConfig.cmake
-- Installing: /usr/local/lib/cmake/libuvc/libuvcConfigVersion.cmake
-- Installing: /usr/local/lib/cmake/libuvc/libuvcTargets.cmake
-- Installing: /usr/local/lib/cmake/libuvc/libuvcTargets-release.cmake
$ sudo ldconfig
$ /usr/bin/cc -o flir ../src/flir.c -luvc
$ lsusb -v
Bus 001 Device 006: ID 09cb:1007
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 239 Miscellaneous Device
bDeviceSubClass 2 ?
bDeviceProtocol 1 Interface Association
bMaxPacketSize0 64
idVendor 0x09cb
idProduct 0x1007
bcdDevice 0.00
iManufacturer 7 FLIR Systems
iProduct 8 FLIR Ex-Series
iSerial 0
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 241
bNumInterfaces 3
bConfigurationValue 1
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 500mA
Interface Association:
bLength 8
bDescriptorType 11
bFirstInterface 0
bInterfaceCount 2
bFunctionClass 14 Video
bFunctionSubClass 3 Video Interface Collection
bFunctionProtocol 0
iFunction 10 FLIR USB Video
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 14 Video
bInterfaceSubClass 1 Video Control
bInterfaceProtocol 0
iInterface 2 FLIR Ex-Series
VideoControl Interface Descriptor:
bLength 13
bDescriptorType 36
bDescriptorSubtype 1 (HEADER)
bcdUVC 1.00
wTotalLength 85
dwClockFrequency 0.001000MHz
bInCollection 1
baInterfaceNr( 0) 1
bLength 18
bDescriptorType 36
bDescriptorSubtype 2 (INPUT_TERMINAL)
bTerminalID 1
wTerminalType 0x0201 Camera Sensor
bAssocTerminal 0
iTerminal 0
wObjectiveFocalLengthMin 0
wObjectiveFocalLengthMax 0
wOcularFocalLength 0
bControlSize 3
bmControls 0x00020260
Focus (Absolute)
Focus (Relative)
Zoom (Absolute)
Focus, Auto
bLength 9
bDescriptorType 36
bDescriptorSubtype 3 (OUTPUT_TERMINAL)
bTerminalID 3
wTerminalType 0x0101 USB Streaming
bAssocTerminal 0
bSourceID 6
iTerminal 0
bLength 7
bDescriptorType 36
bDescriptorSubtype 4 (SELECTOR_UNIT)
bUnitID 4
bNrInPins 1
baSource( 0) 1
iSelector 0
bLength 11
bDescriptorType 36
bDescriptorSubtype 5 (PROCESSING_UNIT)
Warning: Descriptor too short
bUnitID 5
bSourceID 4
wMaxMultiplier 0
bControlSize 2
bmControls 0x00000217
Brightness
Contrast
Hue
Sharpness
Gain
iProcessing 0
bmVideoStandards 0x1b
None
NTSC - 525/60
SECAM - 625/50
NTSC - 625/50
bLength 27
bDescriptorType 36
bDescriptorSubtype 6 (EXTENSION_UNIT)
bUnitID 6
guidExtensionCode {d41f59fa-5094-463a-b3bb-e7858a831fa3}
bNumControl 4
bNrPins 1
baSourceID( 0) 5
bControlSize 2
bmControls( 0) 0x0f
bmControls( 1) 0x00
iExtension 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0008 1x 8 bytes
bInterval 16
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 1
bInterfaceSubClass 2 Video Streaming
iInterface 0
VideoStreaming Interface Descriptor:
bLength 14
bDescriptorType 36
bDescriptorSubtype 1 (INPUT_HEADER)
bNumFormats 1
wTotalLength 79
bEndPointAddress 130
bmInfo 0
bTerminalLink 3
bStillCaptureMethod 0
bTriggerSupport 0
bTriggerUsage 0
bControlSize 1
bmaControls( 0) 27
bLength 27
bDescriptorType 36
bDescriptorSubtype 4 (FORMAT_UNCOMPRESSED)
bFormatIndex 1
bNumFrameDescriptors 1
guidFormat {59555932-0000-1000-8000-00aa00389b71}
bBitsPerPixel 16
bDefaultFrameIndex 1
bAspectRatioX 0
bAspectRatioY 0
bmInterlaceFlags 0x00
Interlaced stream or variable: No
Fields per frame: 2 fields
Field 1 first: No
Field pattern: Field 1 only
bCopyProtect 0
bLength 38
bDescriptorType 36
bDescriptorSubtype 5 (FRAME_UNCOMPRESSED)
bFrameIndex 1
bmCapabilities 0x03
Still image supported
Fixed frame-rate
wWidth 320
wHeight 240
dwMinBitRate 912384
dwMaxBitRate 912384
dwMaxVideoFrameBufferSize 153600
dwDefaultFrameInterval 2666664
bFrameIntervalType 3
dwFrameInterval( 0) 666666
dwFrameInterval( 1) 1333332
dwFrameInterval( 2) 2666664
bLength 7
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0200 1x 512 bytes
bInterval 0
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 8 Mass Storage
bInterfaceSubClass 6 SCSI
bInterfaceProtocol 80 Bulk-Only
iInterface 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x83 EP 3 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x04 EP 4 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
Device Qualifier (for other device speed):
bLength 10
bDescriptorType 6
bcdUSB 2.00
bDeviceSubClass 2 ?
bMaxPacketSize0 64
Device Status: 0x0000
(Bus Powered)
$ sudo libuvc/flir e4-1.raw
UVC initialized
Device found
Device opened
DEVICE CONFIGURATION (09cb:1007/[none]) ---
Status: idle
VideoControl:
bcdUVC: 0x0100
VideoStreaming(1):
bEndpointAddress: 130
Formats:
UncompressedFormat(1)
bits per pixel: 16
GUID: 5955593200001000800000aa00389b71 (YUY2)
default frame: 1
aspect ratio: 0x0
interlace flags: 00
copy protect: 00
FrameDescriptor(1)
capabilities: 03
bit rate: 912384-912384
max frame size: 153600
default interval: 1/3
interval[0]: 1/15
interval[1]: 1/7
interval[2]: 1/3
END DEVICE CONFIGURATION
bmHint: 0000
bFormatIndex: 1
bFrameIndex: 1
dwFrameInterval: 666666
wKeyFrameRate: 0
wPFrameRate: 0
wCompQuality: 0
wCompWindowSize: 0
wDelay: 1
dwMaxVideoFrameSize: 153600
dwMaxPayloadTransferSize: 157696
bInterfaceNumber: 1
Streaming...
got frame 1439397994:439760, 153600 bytes
got frame 1439397994:533467, 153600 bytes
got frame 1439397994:629556, 153600 bytes
got frame 1439397994:726339, 153600 bytes
got frame 1439397994:820088, 153600 bytes
got frame 1439397994:916235, 153600 bytes
got frame 1439397995:22432, 153600 bytes
got frame 1439397995:115699, 153600 bytes
got frame 1439397995:209889, 153600 bytes
got frame 1439397995:304196, 153600 bytes
$ split -b 153600 e4-1.raw
$ convert -size 320x240 yuv:xaa -separate 4.png
$ lsusb -v
Bus 001 Device 008: ID 09cb:1005
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceSubClass 2 ?
bMaxPacketSize0 64
idVendor 0x09cb
idProduct 0x1005
bcdDevice 0.00
iManufacturer 6 FLIR Systems
iProduct 7 FLIR Exx Series
iSerial 0
bLength 9
bDescriptorType 2
wTotalLength 345
bNumInterfaces 4
iConfiguration 0
bmAttributes 0xc0
Self Powered
MaxPower 0mA
bLength 8
bDescriptorType 11
bFirstInterface 0
bInterfaceCount 2
bFunctionClass 2 Communications
bFunctionSubClass 2 Abstract (modem)
bFunctionProtocol 255 Vendor Specific (MSFT RNDIS?)
iFunction 9 FLIR Network Camera
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 2 Communications
bInterfaceSubClass 2 Abstract (modem)
bInterfaceProtocol 255 Vendor Specific (MSFT RNDIS?)
iInterface 0
CDC Header:
bcdCDC 1.10
CDC Call Management:
bmCapabilities 0x00
bDataInterface 1
CDC ACM:
bmCapabilities 0x00
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 4
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 10 CDC Data
bInterfaceSubClass 0 Unused
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x03 EP 3 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 8
bDescriptorType 11
bFirstInterface 2
bInterfaceCount 2
bFunctionProtocol 0
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 0
bNumEndpoints 1
iInterface 4 FLIR Exx Series
bLength 13
bDescriptorType 36
bcdUVC 1.00
wTotalLength 85
bInCollection 1
baInterfaceNr( 0) 3
bLength 18
bDescriptorType 36
bTerminalID 1
bAssocTerminal 0
iTerminal 0
bControlSize 3
Focus (Absolute)
Focus (Relative)
Zoom (Absolute)
Focus, Auto
bLength 9
bDescriptorType 36
bTerminalID 3
bAssocTerminal 0
bSourceID 6
iTerminal 0
bLength 7
bDescriptorType 36
bUnitID 4
bNrInPins 1
baSource( 0) 1
iSelector 0
bLength 11
bDescriptorType 36
bUnitID 5
bSourceID 4
wMaxMultiplier 0
bControlSize 2
Brightness
Contrast
Hue
Sharpness
Gain
iProcessing 0
None
NTSC - 525/60
SECAM - 625/50
NTSC - 625/50
bLength 27
bDescriptorType 36
bUnitID 6
bNumControl 4
bNrPins 1
baSourceID( 0) 5
bControlSize 2
bmControls( 0) 0x0f
bmControls( 1) 0x00
iExtension 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x84 EP 4 IN
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 16
bLength 9
bDescriptorType 4
bInterfaceNumber 3
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 15
bDescriptorType 36
bNumFormats 2
wTotalLength 145
bEndPointAddress 133
bmInfo 0
bTerminalLink 3
bTriggerSupport 0
bTriggerUsage 0
bControlSize 1
bmaControls( 0) 27
bmaControls( 1) 27
bLength 27
bDescriptorType 36
bFormatIndex 1
bBitsPerPixel 16
bAspectRatioX 0
bAspectRatioY 0
Field 1 first: No
bCopyProtect 0
bLength 38
bDescriptorType 36
bFrameIndex 1
bmCapabilities 0x03
Fixed frame-rate
wWidth 320
wHeight 240
dwMinBitRate 912384
dwMaxBitRate 912384
dwDefaultFrameInterval 1333332
dwFrameInterval( 0) 333333
dwFrameInterval( 1) 666666
dwFrameInterval( 2) 1333332
bLength 27
bDescriptorType 36
bFormatIndex 2
guidFormat {46374d30-0000-1000-8000-00aa00389b71}
bBitsPerPixel 16
bAspectRatioX 0
bAspectRatioY 0
Field 1 first: No
bCopyProtect 0
bLength 38
bDescriptorType 36
bFrameIndex 1
bmCapabilities 0x03
Fixed frame-rate
wWidth 320
wHeight 246
dwMinBitRate 912384
dwMaxBitRate 912384
dwMaxVideoFrameBufferSize 157440
bLength 7
bDescriptorType 5
bEndpointAddress 0x85 EP 5 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 10
bDescriptorType 6
bcdUSB 2.00
bDeviceSubClass 2 ?
bMaxPacketSize0 64
Device Status: 0x0001
Self Powered
$ sudo libuvc/flir e40.raw
UVC initialized
Device found
Device opened
DEVICE CONFIGURATION (09cb:1004/0a7f4000-c632-0000-0000-000000000000) ---
Status: idle
VideoControl:
bcdUVC: 0x0100
VideoStreaming(1):
Formats:
bits per pixel: 16
default frame: 1
aspect ratio: 0x0
interlace flags: 00
copy protect: 00
FrameDescriptor(1)
capabilities: 03
default interval: 1/7
interval[0]: 1/30
interval[1]: 1/15
interval[2]: 1/7
UncompressedFormat(2)
bits per pixel: 16
GUID: 46374d3000001000800000aa00389b71 (F7M0)
default frame: 1
aspect ratio: 0x0
interlace flags: 00
copy protect: 00
FrameDescriptor(1)
capabilities: 03
max frame size: 157440
interval[0]: 1/30
interval[1]: 1/15
interval[2]: 1/7
bmHint: 0000
bFormatIndex: 1
bFrameIndex: 1
wKeyFrameRate: 0
wPFrameRate: 0
wCompQuality: 0
wCompWindowSize: 0
wDelay: 1
dwMaxVideoFrameSize: 157440
bInterfaceNumber: 1
Streaming...
got frame 1439394751:346415, 157440 bytes
got frame 1439394751:411283, 157440 bytes
got frame 1439394751:479331, 157440 bytes
got frame 1439394751:546262, 157440 bytes
got frame 1439394751:610415, 157440 bytes
got frame 1439394751:679598, 157440 bytes
got frame 1439394751:741424, 157440 bytes
got frame 1439394751:810494, 157440 bytes
got frame 1439394751:874681, 157440 bytes
got frame 1439394751:938867, 157440 bytes
$ hexdump -C e40.raw
00000000 f4 48 f6 48 f7 48 03 49 04 49 02 49 01 49 00 49 |.H.H.H.I.I.I.I.I|
00000010 14 49 fc 48 ff 48 04 49 fe 48 0a 49 fd 48 0d 49 |.I.H.H.I.H.I.H.I|
000257f0 09 49 19 49 18 49 0e 49 0e 49 0c 49 13 49 32 49 |.I.I.I.I.I.I.I2I|
00025800 46 46 46 00 55 56 43 00 00 00 00 00 00 00 00 00 |FFF.UVC.........|
00025810 00 00 00 00 64 00 00 00 40 00 00 00 02 00 00 00 |....d...@.......|
$ split -b 157440 e40.raw
$ convert -depth 16 -size 320x240 -auto-level gray:xaa 8.png
$ dd if=e40.raw of=e40allframe.ff bs=153600 skip=1
$ exiftool -Date* x*
======== xaa
Date/Time Original : 2015:08:12 17:39:48.413+01:00
======== xab
Date/Time Original : 2015:08:12 17:39:48.479+01:00
======== xac
Date/Time Original : 2015:08:12 17:39:48.545+01:00
======== xad
Date/Time Original : 2015:08:12 17:39:48.611+01:00
======== xae
Date/Time Original : 2015:08:12 17:39:48.677+01:00
======== xaf
Date/Time Original : 2015:08:12 17:39:48.743+01:00
======== xag
Date/Time Original : 2015:08:12 17:39:48.809+01:00
======== xah
Date/Time Original : 2015:08:12 17:39:48.875+01:00
======== xai
Date/Time Original : 2015:08:12 17:39:48.941+01:00
======== xaj
Date/Time Original : 2015:08:12 17:39:49.007+01:00
======== xak
Date/Time Original : 2015:08:12 17:39:49.073+01:00
======== xal
Date/Time Original : 2015:08:12 17:39:49.139+01:00
======== xam
Date/Time Original : 2015:08:12 17:39:49.205+01:00
======== xan
Date/Time Original : 2015:08:12 17:39:49.271+01:00
======== xao
Date/Time Original : 2015:08:12 17:39:49.337+01:00
======== xap
Date/Time Original : 2015:08:12 17:39:49.403+01:00
$ exiftool xaa
ExifTool Version Number : 9.54
File Name : xaa
Directory : .
File Size : 154 kB
File Modification Date/Time : 2015:08:12 18:16:45+02:00
File Access Date/Time : 2015:08:12 18:27:35+02:00
File Inode Change Date/Time : 2015:08:12 18:16:45+02:00
File Permissions : rw-r--r--
File Type : FLIR
MIME Type : application/unknown
Emissivity : 0.95
Object Distance : 1.00 m
Reflected Apparent Temperature : 20.0 C
Atmospheric Temperature : -4.0 C
IR Window Temperature : 20.0 C
IR Window Transmission : 1.00
Relative Humidity : 50.0 %
Planck R1 : 14345.714
Planck B : 1347.7
Planck F : 1
Atmospheric Trans Alpha 1 : 0.006569
Atmospheric Trans Alpha 2 : 0.012620
Atmospheric Trans Beta 1 : -0.002276
Atmospheric Trans Beta 2 : -0.006670
Atmospheric Trans X : 1.900000
Camera Temperature Range Max : 120.0 C
Camera Temperature Range Min : -20.0 C
Camera Model : FLIR E40
Camera Part Number : 49001-2001
Camera Serial Number : 490337633
Camera Software : 20.0.0
Lens Model : FOL18
Lens Part Number :
Lens Serial Number :
Field Of View : 25.0 deg
Filter Model :
Filter Part Number :
Filter Serial Number :
Planck O : -5711
Planck R2 : 0.01234
Raw Value Median : 18457
Raw Value Range : 780
Focus Step Count : 1526
Focus Distance : 5.3 m
$ lsusb -v
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceSubClass 2 ?
bMaxPacketSize0 64
idVendor 0x09cb
idProduct 0x1007
bcdDevice 0.00
iSerial 0
bLength 9
bDescriptorType 2
wTotalLength 241
bNumInterfaces 3
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 500mA
bLength 8
bDescriptorType 11
bFirstInterface 0
bInterfaceCount 2
bFunctionProtocol 0
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bLength 13
bDescriptorType 36
bcdUVC 1.00
wTotalLength 85
bInCollection 1
baInterfaceNr( 0) 1
bLength 18
bDescriptorType 36
bTerminalID 1
bAssocTerminal 0
iTerminal 0
bControlSize 3
Focus (Absolute)
Focus (Relative)
Zoom (Absolute)
Focus, Auto
bLength 9
bDescriptorType 36
bTerminalID 3
bAssocTerminal 0
bSourceID 6
iTerminal 0
bLength 7
bDescriptorType 36
bUnitID 4
bNrInPins 1
baSource( 0) 1
iSelector 0
bLength 11
bDescriptorType 36
bUnitID 5
bSourceID 4
wMaxMultiplier 0
bControlSize 2
Brightness
Contrast
Hue
Sharpness
Gain
iProcessing 0
None
NTSC - 525/60
SECAM - 625/50
NTSC - 625/50
bLength 27
bDescriptorType 36
bUnitID 6
bNumControl 4
bNrPins 1
baSourceID( 0) 5
bControlSize 2
bmControls( 0) 0x0f
bmControls( 1) 0x00
iExtension 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 16
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 14
bDescriptorType 36
bNumFormats 1
wTotalLength 79
bmInfo 0
bTerminalLink 3
bTriggerSupport 0
bTriggerUsage 0
bControlSize 1
bmaControls( 0) 27
bLength 27
bDescriptorType 36
bFormatIndex 1
bBitsPerPixel 16
bAspectRatioX 0
bAspectRatioY 0
Field 1 first: No
bCopyProtect 0
bLength 38
bDescriptorType 36
bFrameIndex 1
bmCapabilities 0x03
Fixed frame-rate
wWidth 320
wHeight 240
dwMinBitRate 912384
dwMaxBitRate 912384
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 0
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 10
bDescriptorType 6
bcdUSB 2.00
bDeviceSubClass 2 ?
bMaxPacketSize0 64
(Bus Powered)
A few hundred lines of code later (simply record all frames with a max temp of higher than some threshold, re-mapping to 8-bit, then encoding as mp4)
orby@ubuntu:~/libuvc/build$ /usr/bin/cc -o flir ../src/flir.c -luvc
../src/flir.c: In function ‘cb’:
../src/flir.c:30:3: warning: format ‘%d’ expects argument of type ‘int’, but argument 2 has type ‘__time_t’ [-Wformat=]
printf("got frame %d:%d, %d bytes\n", tv.tv_sec, tv.tv_usec, frame->data_bytes);
../src/flir.c:30:3: warning: format ‘%d’ expects argument of type ‘int’, but argument 3 has type ‘__suseconds_t’ [-Wformat=]
../src/flir.c:30:3: warning: format ‘%d’ expects argument of type ‘int’, but argument 4 has type ‘size_t’ [-Wformat=]
the result is the known screen image and not a RAW image:(
root@Ubuntu32:/home/some/Temp/libuvc# ./myflir test6.raw
UVC initialized
Device found
Device opened
Status: idle
VideoControl:
bcdUVC: 0x0100
VideoStreaming(1):
Formats:
bits per pixel: 16
default frame: 1
aspect ratio: 0x0
interlace flags: 00
copy protect: 00
FrameDescriptor(1)
capabilities: 03
interval[0]: 1/15
interval[1]: 1/7
interval[2]: 1/3
bmHint: 0000
bFormatIndex: 1
bFrameIndex: 1
wKeyFrameRate: 0
wPFrameRate: 0
wCompQuality: 0
wCompWindowSize: 0
wDelay: 1
bInterfaceNumber: 1
Streaming...
got frame 1439442632:196459, 153600 bytes
got frame 1439442632:290426, 153600 bytes
got frame 1439442632:384196, 153600 bytes
got frame 1439442632:478789, 153600 bytes
got frame 1439442632:573349, 153600 bytes
Done streaming.
Device closed
UVC exited
Since mine is 2.3.0 I spun up a Ubuntu 14.04.3 VM (First time every trying my hand at compiling anything) and got as far at the line listed above before I for the following error:Code: [Select]orby@ubuntu:~/libuvc/build$ /usr/bin/cc -o flir ../src/flir.c -luvc
Everything seemed to go word for word as outlined in tomas123 detailed instructions till that point.
I have no issues saying that I am in way over my head so unless anyone has any suggestions I don't think I can test further.
I would love to get a libuvc with this patch with this working on windows but my limited looking into it seems to indicate that the USB driver wrangling situation to accomplish this would be even more complex.
diff --git a/src/stream.c b/src/stream.c
index 571be16..aabb6ff 100644
--- a/src/stream.c
+++ b/src/stream.c
@@ -183,6 +183,7 @@ uvc_error_t uvc_query_stream_ctrl(
/* prepare for a SET transfer */
if (req == UVC_SET_CUR) {
SHORT_TO_SW(ctrl->bmHint, buf);
+ ctrl->bFormatIndex = 2;
buf[2] = ctrl->bFormatIndex;
buf[3] = ctrl->bFrameIndex;
INT_TO_DW(ctrl->dwFrameInterval, buf + 4);
@@ -222,6 +223,7 @@ uvc_error_t uvc_query_stream_ctrl(
if (req != UVC_SET_CUR) {
ctrl->bmHint = SW_TO_SHORT(buf);
ctrl->bFormatIndex = buf[2];
+ ctrl->bFormatIndex = 1;
ctrl->bFrameIndex = buf[3];
ctrl->dwFrameInterval = DW_TO_INT(buf + 4);
ctrl->wKeyFrameRate = SW_TO_SHORT(buf + 8);
@@ -828,7 +830,7 @@ uvc_error_t uvc_stream_start(
strmh->pts = 0;
strmh->last_scr = 0;
- frame_desc = uvc_find_frame_desc_stream(strmh, ctrl->bFormatIndex, ctrl->bFrameIndex);
+ frame_desc = uvc_find_frame_desc_stream(strmh, ctrl->bFormatIndex - 1, ctrl->bFrameIndex);
if (!frame_desc) {
ret = UVC_ERROR_INVALID_PARAM;
goto fail;
@@ -1037,7 +1039,7 @@ void _uvc_populate_frame(uvc_stream_handle_t *strmh) {
* is going to be reopen_on_change anyway
- frame_desc = uvc_find_frame_desc(strmh->devh, strmh->cur_ctrl.bFormatIndex,
+ frame_desc = uvc_find_frame_desc(strmh->devh, strmh->cur_ctrl.bFormatIndex - 1,
strmh->cur_ctrl.bFrameIndex);
frame->frame_format = strmh->frame_format;
bFormatIndex= 2
dwMaxVideoFrameBufferSize = 157440
bFormatIndex: 1
bFrameIndex: 1
This is only a compiler warning, not an error. I got the excact same warning.
Simple use the successful compiled flir binary.
I don't have my E4 here right now. I'll investigate. Sorry for wasting everyone's time. (It definitely worked for me, as you can see in the youtube video)
What USB mode is your camera in when capturing? (just UVC or one of the mixed modes?)
orby@ubuntu:~$ sudo libuvc/build/flir e4-1.raw
UVC initialized
Device found
Device opened
Status: idle
VideoControl:
bcdUVC: 0x0100
VideoStreaming(1):
Formats:
bits per pixel: 16
default frame: 1
aspect ratio: 0x0
interlace flags: 00
copy protect: 00
FrameDescriptor(1)
capabilities: 03
interval[0]: 1/15
interval[1]: 1/7
interval[2]: 1/3
bmHint: 0000
bFormatIndex: 1
bFrameIndex: 1
wKeyFrameRate: 0
wPFrameRate: 0
wCompQuality: 0
wCompWindowSize: 0
wDelay: 1
bInterfaceNumber: 1
Streaming...
got frame 1439507727:121939, 153600 bytes
got frame 1439507727:122047, 153600 bytes
orby@ubuntu:~$ split -b 153600 e4-1.raw
orby@ubuntu:~$ convert -size 320x240 yuv:xaa -separate 4.png
convert.im6: unexpected end-of-file `xaa': No such file or directory @ error/yuv.c/ReadYUVImage/428.
Meh. Okay.
I'm on 2.3, so maybe it was added later. Could someone with a Flir Ex with 2.3 firmware give it a try? I wouldn't know what else it could be.
4-0.png PNG 320x240 320x240+0+0 16-bit sRGB 67.3KB 0.000u 0:00.001
>convert -define png:swap-bytes=on 4-0.png -auto-level raw.png
convert -depth 16 -size 320x240 -auto-level gray:xaa raw.png
UVC initialized
Device found
Device opened
Status: idle
VideoControl:
bcdUVC: 0x0100
VideoStreaming(1):
Formats:
bits per pixel: 16
default frame: 1
aspect ratio: 0x0
interlace flags: 00
copy protect: 00
FrameDescriptor(1)
capabilities: 03
interval[0]: 1/15
interval[1]: 1/7
interval[2]: 1/3
bmHint: 0000
bFormatIndex: 1
bFrameIndex: 1
wKeyFrameRate: 0
wPFrameRate: 0
wCompQuality: 0
wCompWindowSize: 0
wDelay: 1
bInterfaceNumber: 1
Streaming...
@Orby
your png-image is radiometric with swapped bytes
see my tutorial here: https://www.eevblog.com/forum/testgear/flir-e4-thermal-imaging-camera-teardown/msg348398/#msg348398Code: [Select]>identify 4-0.png
better use the splitted partCode: [Select]convert -depth 16 -size 320x240 -auto-level gray:xaa raw.png
@Orby + @Bud
You have both the firmware 2.3.0.
Find the difference between the configuration
check "lsusb -v"
our logs from flir.c are 100% identicalCode: [Select]UVC initialized
Device found
Device opened
Status: idle
VideoControl:
bcdUVC: 0x0100
VideoStreaming(1):
Formats:
bits per pixel: 16
default frame: 1
aspect ratio: 0x0
interlace flags: 00
copy protect: 00
FrameDescriptor(1)
capabilities: 03
interval[0]: 1/15
interval[1]: 1/7
interval[2]: 1/3
bmHint: 0000
bFormatIndex: 1
bFrameIndex: 1
wKeyFrameRate: 0
wPFrameRate: 0
wCompQuality: 0
wCompWindowSize: 0
wDelay: 1
bInterfaceNumber: 1
Streaming...
A interesting difference to my E40 stream:
The E4 RAW stream contains no FFF Header:
Image Size: 320x240x2 Byte = frame size = 153600 Byte
The E40 RAW Stream contains full FFF Imgages
frame size 157440 byte
see sample in my post https://www.eevblog.com/forum/testgear/flir-ex-realtime-raw-radiometric-data-streaming-via-uvc/msg729688/#msg729688
$ convert -depth 16 -size 320x240 gray:xaa raw.png
$ php splitjpg.php -i IR_0xxx.jpg -r raw.png -o sample
Load the sample.jpg in Flir Tools
