Two more poorly Seek Thermal Reveal cameras are currently on their way to me for some TLC
The two cameras came up on eBay as a faulty pair, which in itself is rare. These cameras are generally pretty reliable and many faults stem from being dropped or other abuse by the user. This particular pair of cameras caught my eye as they are the popular XR (20 Degree FOV) model in the Camouflage casing design. Hunters seem to like these for spotting game. One unit is the Fast Frame (>15fps) model and the other appears to be the Slow Frame version.
In recent auctions for faulty Seek Reveal units they have still commanded reasonable money and this was factored into my valuation for bidding purposes. When fully operational the value increases significantly, as would be expected
The two Seek Reveal XR units are sold as faulty and the seller has excellent feedback so hopefully no one has already been fiddling inside them. For two cameras to fail with the same “no thermal image” fault is unusual, as already stated. This also captured my interest. The fault could be something as simple as the imaging Core flexible cable breaking free from the main board, or it could be something more challenging, or even unrepairable. We shall see.
So what was my assessment of the two units before placing my bids ?
1. Casings appear to be undamaged
2. Display glass is not damaged and one has a protector, suggesting a caring owner.
3. Button pad is undamaged
4. Camera boots
5. Camera indicates a charged battery
6. Menu system is operative
7. Camera is running but the thermal image is black / absent
Both cameras have the same symptoms and are as above.
To me this suggests a camera in which the operating system is operational so hopefully we are not dealing with a corruption of a flash storage or failed firmware update as I would expect issues with the boot and/or menu system. The lack of any image information or noise being present on the thermal image display suggests to me that the image processor is not receiving any valid data on its digital inputs. The A to D takes place in the core module. The core module may be either disconnected from the main PCB or there is no power getting to it. If the core module is missing I will be having words with the seller, but such is unlikely as the core is useless on its own.
Could the wrong firmware have been installed and caused a compatibility issue with the core .... such a installing Pro software in the standard Reveal? This is unlikely as I believe the update would identify the wrong platform and not install. The Reveal and Reveal PRO use different chipsets so even if the firmware installed the camera would be bricked. As already stated, a corrupted firmware update is always a possibility, especially if someone is experimenting with modifications to the firmware. But to damage two cameras in this way and for them to still function apart from the thermal image ? Hmmm I doubt it.
When the two units arrive on Saturday (Hopefully) I will assess their symptoms first hand And then remove the bottom half of the casing to check the cores ribbon connection. If all is well with that I will remove the front panel that holds the core and check the ribbon connection at the core. If nothing is found, I will start my usual assessment and diagnostics process to determine what is going on with the cameras. I will have my standard Reveal Camera to use as a reference unit as well
I attach the auction pictures. Considering I was buying two of the XR camouflage models and one is the FF model, the price was right
As stated in the post title...... a calculated risk.
Fraser
