Author Topic: Flir E40 Upgrade & Configuration  (Read 176130 times)
Offline Pinkus
Re: Flir E40 Upgrade & Configuration
« Reply #275 on: April 04, 2018, 10:01:16 pm »
Send me your email address as a PM and I will send it to you.
Offline Zucca
  • EE meid in Itali
« Reply #276 on: April 05, 2018, 03:19:37 am »
I'm looking for the old firmware 2.23.14 (Exx without MSX)
Can anybody upload the file flir_exx_pn490_v2.23.14_update_pack.zip from FLIR Exx P/N:490xx (2.23.14) Update Pack
https://www.eevblog.com/forum/thermal-imaging/just-got-an-e30bx-have-the-usual-questions/msg1400320/#msg1400320
Offline Zucca
  • EE meid in Itali
« Reply #277 on: April 05, 2018, 03:41:03 am »
Note that some options in the configuration file actually restrict the cameras functionality so do not activate PiP lock or anything that appears to be restriction. Some of the config lines that are either already a active (True) or that you make active have a line below them with the ending 'Int' these set the valuecassociated with the function above. In the case of measurement functions, this setting can set the number of spot temperatures or measurement boxes you can have on the screen. Take a look at my configuration file and compare your "Int" values.  I have multiple spot and box measurements. I also enabled circle measurement areas and special functions like the Sketch capability that lets you use the touch screen to draw on a saved image to highlight a point of interest when doing a survey. I enabled image editing and any other useful features I found. Take a close look at my configuration file. You can actually use my complete configuration file in your camera provided you edit the serial number and calculate the CRC01 for your serial number and configuration file.
I have all the above functions,but i can not get the MIN values in lines,box or circles etc.. Only the MAX values are showing up. Moreover i spent 30minute to add the graph under the line like the one below but no luck. Something wrong with my config? Sorry I can't send a screenshot because this orrible ipad don't have the sd card reader....
« Last Edit: April 05, 2018, 03:52:43 am by zucca »
Offline Zucca
  • EE meid in Itali
« Reply #278 on: April 05, 2018, 04:02:26 pm »
https://www.eevblog.com/forum/thermal-imaging/flir-e40-upgrade-configuration/msg1434799/#msg1434799
forgot to change the .caps.config.image.sysimg.measureFuncs.mline.maxCount int32 to value 1 instead of 5...
still don´t know why I got only MAX Value and no graph at all under the line, box or circle. needs investigation... maybe the .caps.config.revision text "1.1" need to be .caps.config.revision text "0.1"
« Last Edit: April 05, 2018, 04:19:32 pm by zucca »
Offline Paw85
« Reply #279 on: April 05, 2018, 06:25:03 pm »
Good you found my previous post to set that value correctly.
Regarding only MAX and no graph, are you aware of the menu [Tools] -> [Adjust tools] and scroll to the tool you have on your screen and press OK, there you should be able to toggle things like Graph, Max, Min, Avrage, Markers, Alarm.
Let me know if you cant find the menu :)
Offline Zucca
  • EE meid in Itali
« Reply #281 on: April 06, 2018, 03:28:50 am »
My pleasure tomas123, now I need to learn all your SW... you did so much.
Paw85 cheers!
Sorry I did not RTFM.
« Last Edit: April 06, 2018, 03:41:47 am by zucca »
Offline Zucca
  • EE meid in Itali
« Reply #282 on: April 06, 2018, 10:09:26 pm »
Can't believe I have this...  :-+
https://archive.org/embed/FlirE60BxIrInfraredThermalImagingCamera/FlirE60BxIrInfraredThermalImagingCamera.mp4
Do you know if it is possible to videostream the IR image on the E60+ screen over WIFI? Should I just use the app?
« Last Edit: April 06, 2018, 10:12:08 pm by zucca »
Offline tomas123
« Reply #283 on: April 06, 2018, 11:53:06 pm »
We have not yet reversed engineered the WiFi stream.
All known hacks for streaming are for a USB connection.
Offline Spirit532
  • Country: by
    • My website
« Reply #284 on: April 07, 2018, 09:43:20 am »
The WiFi stream seems to be RTSP or RTP, depending on your settings, and it seems to be visual-only, but without the overlay.
I may be wrong about this.
Offline tomas123
« Reply #285 on: April 07, 2018, 03:04:26 pm »
yes, but this is a regular video and not a 16 bit thermal stream
from my old notes (year 2013):
Quicktime player
open address
rtsp://192.168.64.1
ca. 350Kb/sec Frame rate: 19.2
480 × 360
from manual:
rset.quality
Encoding quantization level. Range 1-31. Default value = 7. A low value means higher quality picture. Encoding quality is also dependent on the maximum bit rate allowed.
you can change the quality during a running stream:
>rset rtp.quality 1
-> ca. 500 KB/sec (quality is visible better) Frame rate: 8.0
Offline kaz911
« Reply #286 on: April 24, 2018, 08:43:57 am »
got my self a E50bx Mk 1 late 2012 with the 45deg/10mm lens at a reasonable price.
Now liberated - to thanks to all! Did update via FTP w/ Fraser's App/Gui codes - so thanks to Mike, Thomas, Gustavo? & Fraser for all their work! and everybody else here.
The E50bx 10mm lens is calibrated from factory and have both -20-120 & 0-650 range
But the built in lens is only calibrated to -20-120 - so I guess i have to play with files to enable the 0-650 range.
But quality of the -20-120 range is super! And I tried it against my old E4 libaratio - and there is so much more detail in the E50bx files. But I do miss the MSX...
Offline Zucca
  • EE meid in Itali
« Reply #287 on: April 24, 2018, 12:57:57 pm »
Welcome to the club, the EXX is a natural evolution of E4... very impressive indeed.
It looks like the EXXbx model can be open to the 0-650 range but there are no much information regarding the calibration of that second range.
I got a E30 which is only 0-350 with no further calibration.
Offline Fraser
« Reply #288 on: April 24, 2018, 01:46:39 pm »
Kaz911,
The second temperature range is enabled via the cameras Service Menu and not in the configuration files. You only need to enter the service menu via a web browser, enter the 3vlig and 1235 passwords and you can add range 2. Hopefully your camera has the required calibration tables present.
Fraser
Offline kaz911
« Reply #289 on: April 24, 2018, 02:48:23 pm »
Kaz911,
Fraser
I was trying to convey :) that I have calibration for the 0-650 ONLY when I add the 10mm lens. There I have calibration for -20 to 120 and 0 to 650
The 0-650 calibration is not there for the normal ?18mm lens (the standard lens) - so standard lens only have the calibration for -20 to 120.
so currently I can only do 0-650 when I put the 10mm lens on. :)
I have looked in the "service menu" which confirms the above - 3 ranges calibrated - 2 for the 10mm and 1 for the built in lens.
/k
Offline Zucca
  • EE meid in Itali
« Reply #290 on: April 24, 2018, 03:00:46 pm »
Interesting
Offline Fraser
« Reply #291 on: April 24, 2018, 04:37:56 pm »
Kaz911,
Ah, apologies, I did not realise that you had already looked at the service menu.
Your situation is unusual. It is not uncommon for early MK1 'bx' suffix cameras to only have range 1 calibration tables, but I had not heard of FLIR providing Range 2 calibration for a supplementary lens on such a camera. I suspect their automated calibration rig just generates the calibration files for Range 1 and 2, no matter which camera is attached to the supplementary lens at the time of testing.
It is possible to calibrate the camera for any Range using the service menu, but the correct high and low temperature Black Body thermal sources are needed.
As a side not on calibration..... Interestingly, whilst working on an early i5 recently, I found the production log for its calibration. It was clear that the camera had undergone an automated calibration routine that obeyed a set of 'on-board' camera 'descriptors' in order to produce only the required resolution and ranges. Thankfully I do not think the Exx series used such a calibration process and just the service menu is needed for calibration.
Fraser
Offline Jorkah
« Reply #292 on: May 10, 2018, 01:07:19 pm »
I'm looking for the old firmware 2.23.14 (Exx without MSX) .
The old link goes to current FW 2.27.16.
http://support.flir.com/SwDownload/app/RssSWDownload.aspx?ID=127
Can anybody upload the file flir_exx_pn490_v2.23.14_update_pack.zip from FLIR Exx P/N:490xx (2.23.14) Update Pack ?
Thanks for help.
I have the same problem, the link also links to the newer firmware (2.27.16). Can anybody please re-upload it?
Thanks!
Offline Zucca
  • EE meid in Itali
« Reply #293 on: May 10, 2018, 01:15:53 pm »
Just look above
Offline Jorkah
« Reply #294 on: May 10, 2018, 02:02:07 pm »
I already tried the link (filedropper) posted by Fraser, but it doesn’t work anymore.
14-5-2018 Update:
I've got my E40bx upgraded with all the functions!
I would like to thank tomas123, Frazer and Paw85 for their input, real good work you did, very interesting! Special thanks to Pinkus, who provided me the necessary firmware!
Jorkah
« Last Edit: May 14, 2018, 11:11:25 am by Jorkah »
Offline Zucca
  • EE meid in Itali
« Reply #295 on: May 15, 2018, 04:55:16 pm »
I uploaded the FW here
ftp://ftp.xdevs.com/Flir/Exx/FW/flir_exx_pn490_v2.23.14_update_pack.zip
thanks to TiN ftp server, here how to connect:
https://doc.xdevs.com/contact/
Z
« Last Edit: June 07, 2018, 12:26:46 pm by zucca »
Offline Garry2
« Reply #296 on: May 23, 2018, 02:39:03 am »
I have a e30 and have followed all the steps I can find on the thread, but can not get "thermal fusion" and "picture in picture" to work. The options are shown in the menu, but grayed out and can not be selected. I got this camera pre modified and do not have access to the original files. This is what I have for my conf files. I have redone my crc values. On firmware 2.23.14
appcode
.caps entry
.caps.config entry
.caps.config.name text "app E60"
.caps.config.revision text "0.10"
.caps.config.image entry
.caps.config.image.framegrab entry
.caps.config.image.framegrab.fusion entry
.caps.config.image.framegrab.fusion.enabled bool true
.caps.config.image.sensor entry
.caps.config.image.sensor.enabled bool true
.caps.config.image.services entry
.caps.config.image.services.store entry
.caps.config.image.services.store.enabled bool true
.caps.config.image.services.store.radiometric entry
.caps.config.image.services.store.radiometric.enabled bool true
.caps.config.image.services.store.incompatible entry
.caps.config.image.services.store.incompatible.enabled bool false
.caps.config.image.services.store.incompatible.level int32 0
.caps.config.image.settings entry
.caps.config.image.settings.enabled bool true
.caps.config.image.settings.downsample bool false
.caps.config.image.settings.resIR int32 320
.caps.config.image.sysimg entry
.caps.config.image.sysimg.alarms entry
.caps.config.image.sysimg.alarms.enabled bool true
.caps.config.image.sysimg.alarms.measfunc entry
.caps.config.image.sysimg.alarms.measfunc.enabled bool true
.caps.config.image.sysimg.alarms.measfunc.maxCount int32 2
.caps.config.image.sysimg.alarms.humidity entry
.caps.config.image.sysimg.alarms.humidity.enabled bool true
.caps.config.image.sysimg.alarms.humidity.maxCount int32 2
.caps.config.image.sysimg.alarms.insulation entry
.caps.config.image.sysimg.alarms.insulation.enabled bool true
.caps.config.image.sysimg.alarms.insulation.maxCount int32 2
.caps.config.image.sysimg.irMarkers entry
.caps.config.image.sysimg.irMarkers.enabled bool true
.caps.config.image.sysimg.irMarkers.spot entry
.caps.config.image.sysimg.irMarkers.spot.enabled bool true
.caps.config.image.sysimg.irMarkers.spot.maxCount int32 2
.caps.config.image.sysimg.irMarkers.arrow entry
.caps.config.image.sysimg.irMarkers.arrow.enabled bool true
.caps.config.image.sysimg.irMarkers.arrow.maxCount int32 2
.caps.config.image.sysimg.irMarkers.box entry
.caps.config.image.sysimg.irMarkers.box.enabled bool true
.caps.config.image.sysimg.irMarkers.box.maxCount int32 2
.caps.config.image.sysimg.measureFuncs entry
.caps.config.image.sysimg.measureFuncs.enabled bool true
.caps.config.image.sysimg.measureFuncs.diff entry
.caps.config.image.sysimg.measureFuncs.diff.enabled bool true
.caps.config.image.sysimg.measureFuncs.diff.maxCount int32 2
.caps.config.image.sysimg.measureFuncs.diff.calcMask int32 65526
.caps.config.image.sysimg.measureFuncs.isotherm entry
.caps.config.image.sysimg.measureFuncs.isotherm.enabled bool true
.caps.config.image.sysimg.measureFuncs.isotherm.calcMask int32 20
.caps.config.image.sysimg.measureFuncs.isotherm.dual bool true
.caps.config.image.sysimg.measureFuncs.isotherm.fixScale bool false
.caps.config.image.sysimg.measureFuncs.isotherm.interval bool true
.caps.config.image.sysimg.measureFuncs.isotherm.invInterval bool false
.caps.config.image.sysimg.measureFuncs.isotherm.maxCount int32 5
.caps.config.image.sysimg.measureFuncs.mbox entry
.caps.config.image.sysimg.measureFuncs.mbox.enabled bool true
.caps.config.image.sysimg.measureFuncs.mbox.calcMask int32 1924
.caps.config.image.sysimg.measureFuncs.mbox.maxCount int32 5
.caps.config.image.sysimg.measureFuncs.mcircle entry
.caps.config.image.sysimg.measureFuncs.mcircle.enabled bool true
.caps.config.image.sysimg.measureFuncs.mcircle.calcMask int32 1924
.caps.config.image.sysimg.measureFuncs.mcircle.maxCount int32 5
.caps.config.image.sysimg.measureFuncs.mline entry
.caps.config.image.sysimg.measureFuncs.mline.enabled bool true
.caps.config.image.sysimg.measureFuncs.mline.calcMask int32 1924
.caps.config.image.sysimg.measureFuncs.mline.maxCount int32 5
.caps.config.image.sysimg.measureFuncs.reftemp entry
.caps.config.image.sysimg.measureFuncs.reftemp.enabled bool true
.caps.config.image.sysimg.measureFuncs.reftemp.calcMask int32 1924
.caps.config.image.sysimg.measureFuncs.reftemp.maxCount int32 1
.caps.config.image.sysimg.measureFuncs.script entry
.caps.config.image.sysimg.measureFuncs.script.enabled false
.caps.config.image.sysimg.measureFuncs.script.maxCount int32 0
.caps.config.image.sysimg.measureFuncs.spot entry
.caps.config.image.sysimg.measureFuncs.spot.enabled bool true
.caps.config.image.sysimg.measureFuncs.spot.calcMask int32 514
.caps.config.image.sysimg.measureFuncs.spot.maxCount int32 5
.caps.config.image.sysimg.visualMarkers entry
.caps.config.image.sysimg.visualMarkers.enabled bool true
.caps.config.image.sysimg.visualMarkers.spot entry
.caps.config.image.sysimg.visualMarkers.spot.enabled bool true
.caps.config.image.sysimg.visualMarkers.spot.maxCount int32 5
.caps.config.image.sysimg.visualMarkers.arrow entry
.caps.config.image.sysimg.visualMarkers.arrow.enabled bool true
.caps.config.image.sysimg.visualMarkers.arrow.maxCount int32 5
.caps.config.image.sysimg.visualMarkers.box entry
.caps.config.image.sysimg.visualMarkers.box.enabled bool true
.caps.config.image.sysimg.visualMarkers.box.maxCount int32 5
.caps.config.image.targetNoise entry
.caps.config.image.targetNoise.enabled bool false
.caps.config.image.targetNoise.targetNoiseMk int32 0
.caps.config.image.zoom entry
.caps.config.image.zoom.enabled bool true
.caps.config.image.zoom.maxFactor double 8
.caps.config.system entry
.caps.config.system.focus entry
.caps.config.system.focus.laser entry
.caps.config.system.focus.laser.updateFocus entry
.caps.config.system.focus.laser.updateFocus.enabled bool false
ui
.caps entry
.caps.config entry
.caps.config.name text "GUI E60"
.caps.config.IIG entry
.caps.config.IIG.enabled bool true
.caps.config.IIG.DC int32 1
.caps.config.IIG.IR int32 1
.caps.config.IIG.canvasSketches int32 0
.caps.config.IIG.IRImageSketch bool false
.caps.config.IIG.DCImageSketch bool false
.caps.config.IIG.textAnnotations int32 1
.caps.config.IIG.videos int32 1
.caps.config.IIG.voiceAnnotations int32 1
.caps.config.IIG.objects int32 5
.caps.config.image.enabled bool true
.caps.config.image.adjust entry
.caps.config.image.adjust.enabled bool true
.caps.config.image.adjust.auto bool true
.caps.config.image.adjust.interval bool true
.caps.config.image.adjust.above bool false
.caps.config.image.adjust.below bool false
.caps.config.fusion entry
.caps.config.fusion.enabled bool true
.caps.config.fusion.thermal entry
.caps.config.fusion.thermal.enabled bool true
.caps.config.fusion.thermal.auto bool true
.caps.config.fusion.thermal.interval bool true
.caps.config.fusion.thermal.above bool true
.caps.config.fusion.thermal.below bool true
.caps.config.fusion.PIP entry
.caps.config.fusion.PIP.enabled bool true
.caps.config.fusion.PIP.locked bool false
.caps.config.laser entry
.caps.config.laser.enabled bool true
.caps.config.laser.positionMarker bool true
.caps.config.measure entry
.caps.config.measure.enabled bool true
.caps.config.measure.emissivityTable entry
.caps.config.measure.emissivityTable.enabled bool true
.caps.config.measure.externWindow entry
.caps.config.measure.externWindow.enabled bool true
.caps.config.measure.localObjectParams entry
.caps.config.measure.localObjectParams.enabled bool false
.caps.config.measure.screening entry
.caps.config.measure.screening.enabled bool false
.caps.config.mode entry
.caps.config.mode.enabled bool true
.caps.config.mode.program bool false
.caps.config.mode.panorama bool false
.caps.config.mode.video bool true
.caps.config.mode.radiometricVideo bool false
.caps.config.menu entry
.caps.config.menu.enabled bool true
.caps.config.menu.presets bool false
.caps.config.save entry
.caps.config.save.enabled bool true
.caps.config.save.simultaneous bool true
.caps.config.save.fastShoot bool false
.caps.config.report entry
.caps.config.report.enable bool true
.caps.config.report.createPdf bool true
Offline Jorkah
« Reply #297 on: May 25, 2018, 10:06:18 am »
I have used the following code, everything is working fine.
appcode:
# Generated at 2011-04-28 17:34:36
.caps entry
.caps.config entry
.caps.config.image.framegrab.fusion.hcf entry
.caps.config.image.framegrab.fusion.hcf.enabled bool true
.caps.config.image.sysimg.measureFuncs.mline.maxCount int32 1
ui:
.caps entry
.caps.config entry
.caps.config.IIG.canvasSketches int32 3
.caps.config.IIG.IRImageSketch bool true
.caps.config.IIG.DCImageSketch bool true
.caps.config.image.adjust.above bool true
.caps.config.image.adjust.below bool true
.caps.config.measure.localObjectParams.enabled bool true
.caps.config.mode.program bool true
Offline Garry2
« Reply #298 on: May 28, 2018, 03:31:23 am »
Thanks Jorkah, that added an additional option in the menu, "MSX", but all 3 are grayed out. I can still only select thermal and digital. I am wondering if my camera is missing the files that point to those options.
Offline eKretz
« Reply #299 on: June 07, 2018, 07:21:16 am »
thanks to TiN ftp server.
Z
Might need this soon but tried to download and it's asking for username and password.
