Okay,
Just to resume, can one of you confirm i am on the right track
- First i made a backup of config.cfg from the camera
- Downloaded my conf.cfg file from the E40 to pc
- Copied it to same map as where i unzipped the e4hack3c.zip files
- I have edit my conf.cfg file, i changed 645xxxx to the original serial number (leaving the old CRC01 number untouched)
- Changed my resolution settings:
.caps.config.image.settings.resIR int32 320 and
.caps.config.image.targetNoise.targetNoiseMk int32 0- Take care you have one free line on the end of the text file
(CRLF is not \r\n\command ?)- Save file
- Run the E8.cfg and on the prompt you receive a new CRC01 number
(or do i need to copy paste my file text in to the E8.cfg ?)- Remove the old CRC number in your file, and replace this with the new generated CRC01
Do i need to zip the config.cfg file and change it to .fif extension? to run back in too the E40 ?
As a few things are different to a E4 in terms explanation, i get a bit unsure
![Scared :scared:](https://www.eevblog.com/forum/Smileys/default/scared.gif)
, and don't like to end up with a brick as result
I am not very familiar with computers these days, and CD / \ stuff was a long.... time ago. so bare with me guys.
![Phew :phew:](https://www.eevblog.com/forum/Smileys/default/phew.gif)
