Author Topic: Flir E40 focus add damping oil  (Read 2110 times)
Offline laywsTopic starter
« on: January 26, 2017, 05:28:01 am »
My flir E40 not new and focus too loose.
I add damping oil to the focus foam. I do not know is right.
The focus damping very good now.
Re: Flir E40 focus add damping oil
« Reply #1 on: January 26, 2017, 08:00:39 pm »
You need a high kilopoise oil, which is an oil ( most commonly a silicone oil) that is very thick, and which is still going to be very thick from around -20C to around 70C for there, or use a silicone grease. Very commonly used on optics as a damper.
« Reply #2 on: January 27, 2017, 06:54:20 am »
I check the datasheet as silicon oil.
  Operating temperature:0-120C
   Torque value ?20gf.cm
« Reply #3 on: January 28, 2017, 09:52:29 pm »
Good enough, will work there. You get some crazy high viscosity oils used as motor drive damping, they were common on old Micropolis hard drives as stepper actuator damping in a mass damper on the shaft end. No effect in slow, but rapid stepping was damped down quite effectively and it reduced resonances in the drive head assembly quite well.
« Reply #4 on: February 03, 2017, 11:32:03 am »
Using other mode, very good than the damping oil.  >:D
Please see the attached picture.
