Good enough, will work there. You get some crazy high viscosity oils used as motor drive damping, they were common on old Micropolis hard drives as stepper actuator damping in a mass damper on the shaft end. No effect in slow, but rapid stepping was damped down quite effectively and it reduced resonances in the drive head assembly quite well.
