Hey there Bud,
Thanks for all the hard work. I applied the basic and advanced packages. I may be doing something incorrectly (just got my first FLIR), but I believe I found a bug.
With the advanced package installed, if I select Object Distance from Image mode, whatever value I select seems to be multiplied by 3.33. If I select 0 ft, it is 0 ft, 1 ft = 3 ft, 10 ft = 33 ft, 2000 ft = 6562 ft.
Thank you others for the discussion on lens for PCB work, we hope to use one of these in a grad research lab.
