Bud, sorry to take up your time with my questions.
But if you have the opportunity, could you look at this:
On my camera I have the following “Measurement” options”
- No Measurements
- Center Spot
- Hot Spot (center spot & hottest spot within the brackets)
- Cold Spot (center spot & coldest spot within the brackets)
- 3 Spots (3 spots next to each other, the middle one like the normal center spot)
- Hot Spot – Spot (center spot & hottest spot within the brackets & ?T between those two)
- Hot Spot – Temp (hottest spot within the brackets & user pre-set Temp & ?T between those two)
When I check your “Basic Hack” files, in the ui.d/presets.d folder, I find these .rsc files:
- preset_centerHotColdSpot
- preset_centerspot
- preset_deltaSpot
- preset_deltaTemp
- preset_fiveSpots
- preset_hotColdSpot
- preset_nomeasure
- preset_threeSpots
- preset_twoHotSpots
Why are not all measurement options showing on my camera?
(Or are they not supposed to yet, but part of the advanced hack?)
I was also wondering, if during your feature discovering journey you have stumbled on a function that can be unlocked to have this feature:
Center Spot & Hottest Spot & Coldest Spot within the brackets
and :
Either be able to resize the brackets, or have them cover a larger area than they are now with the “Hot Spot” and “Cold Spot” functions?
And if not, would it be possible to adjust the text in the .rsc files to construct my own preset and just (re)name that to for example “preset_threeSpots”, since I won’t be using the “threeSpots” function?
Or are these .rcs files not adjustable this way and need their operation be facilitated in some other part of the software?
Other thing I was wondering is about the autoNUC.
Although OrBy’s method of (temporarily) disabling the autoNUC function by means of running the .fif file works, sometimes the camera freezes and I have to (hard) reset it (by holding the ON/OFF button 6 seconds and removing the battery for a few seconds). Then the camera looses this feature and autoNUC is back at it..
When this happens while I’m away from my PC, I can’t get it back.
Some camera’s, like the WIRIS Gen 2, allow you to change the autoNUC mode in the settings menu, where you can choose between “auto”, “every 1 minute”, “every 5 minutes” and “manual”.
Have you come across such similar function or feature while discovering and unlocking the E4 possibilities?
