Author Topic: FLIR E4 Wifi Resolution and Menu Hack Thread  (Read 478736 times)
Offline Theremin
Re: FLIR E4 Wifi Resolution and Menu Hack Thread
« Reply #1300 on: December 14, 2023, 05:05:13 pm »
It was a new camera, did you charge the battery before using?
Things you can try:
Unplug the battery for 1 min, plug it again. Connect the wall charger to the camera. Push Left and Right keys together. Do you see the screen showing battery charging? What is charge level? Let the battery charge. If charge level is low, leave the camera charging for a few hours. You can monitor charge level on the screen.
I charged it for a few hours before turning it on the first time and saw the battery icon then. Nothing showing now after doing what you said and pressing the buttons. Maybe the battery just died. Although I remember reading somewhere that it should get enough power from USB to start the recovery, but I'm not sure, could have been for some other model.
The calibration date on the included information card says June 2019, so it likely has been sitting in some warehouse for fours years in who knows what environmental conditions. Perhaps time to RMA it.
Offline DaveWBTopic starter
« Reply #1301 on: December 14, 2023, 05:15:17 pm »
I bet the internal battery is dead
Online Bud
« Reply #1302 on: December 14, 2023, 07:01:26 pm »
If the camera even not charging and not enumerating in USB while powered off that is certainly a hardware failure....
And you also tried to connect it to USB with the battery removed, correct?
Offline Theremin
« Reply #1303 on: December 18, 2023, 08:57:04 am »
I tried with the battery removed, no change. I'll send it for repair.
Offline Theremin
« Reply #1304 on: December 21, 2023, 09:50:03 am »
Turns out the camera was shipped from Flir too long ago and doesn't even have warranty anymore, so I'll get a full refund. The dealer offered to sell E5-XT for the same price. I read from the previous page that someone had successfully liberated that model as well, but would you say it's still wiser to get the E4 model just to be on the safe side? No idea with what firmware version either one comes with at this point. And liberating the E5-XT could mean losing the extended temperature range anyway from what I read.
« Reply #1305 on: December 21, 2023, 11:17:11 am »
Taking the E5 would be totally fine and same process
The following users thanked this post: Theremin, Leak Detector
Online smaultre
« Reply #1306 on: January 21, 2024, 12:40:43 am »
Hello. I need a full dump of Flash  IC TC58BVG1S3HTA00
Please!!!
Mine goes bad, and device won't boot.
Start a new life here!!!
Offline Mikiej007
« Reply #1307 on: February 11, 2024, 04:10:36 pm »
I'm looking to liberate my (non-WiFi) E4 after it was gifted to me as part of a redundancy and company shut down.
I believe that it has never been upgraded and is still on very old firmware.
Model  E4 1.0
Part Number  63901-0101
Software  1.19.8
Looking though the thread, it is recommended to leave 1.19 as is, but I would really like to unlock the higher resolution and any menu/functionality improvements.
What would be the best way to go forward. Can I just use Buds procedure, or should I do an intermediate update first?
Thanks, in advance.
Online Bud
« Reply #1308 on: February 11, 2024, 04:33:27 pm »
For Bud's procedure you should check the WiFi thread for compatible firmware version numbers.
Offline Mikiej007
« Reply #1309 on: February 11, 2024, 06:42:42 pm »
Yeah I did a search but 1.19 doesn't really get mentioned much, hence my question about the possible need to update to a different standard firmware and then do the hack?
« Reply #1310 on: February 11, 2024, 06:45:44 pm »
Just upgrade to 3.16.0 and go from there, all the hardware versions can be upgraded.
Offline SWAGGYD
« Reply #1311 on: March 12, 2024, 03:19:11 pm »
Hi
I juts upgrade my E4 3.16, every think is ok but I don't know how to turn off RNDS. Can someone help me?
Offline xrazzed
« Reply #1312 on: July 18, 2024, 07:35:38 pm »
Hello guys, please help.
I have Flir e6 3.16.0. I set this thing to RNDIS mode and now interface doesnt work.. how to disable it? how to restore it??
Online Bud
« Reply #1313 on: July 19, 2024, 04:43:02 am »
Explain in details what you did to set it to RNDIS mode and what it means "interface does not work".
Offline xrazzed
« Reply #1314 on: July 19, 2024, 05:13:16 pm »
I used guide from this website:   https://fubar.gr/hacking-the-flir-e4/
what did i do: I used a program called  "Flir Install 2" and as in guide i did select "Set_RNDIS_permament.fif" and ran it. After that i restarted my camera by taking battery off and after loading something went wrong ill attach screenshots.
Photo where my flir shows cup: interface is frozen, camera doesnt react on any of buttons, only if i hold power button for 3-4 seconds its turning off.
Offline xrazzed
« Reply #1315 on: July 19, 2024, 05:15:32 pm »
Also Bud, if u want we can have a skype call or something so u can fully understand my situation. Thanks!  :)
Online Bud
« Reply #1316 on: July 19, 2024, 05:52:37 pm »
What made you use a procedure intended for E4 v2.3.0 on your E6 v3.16.0 ?
Where did  you get ""Flir Install 2" program?  Is it an executable from Flir Tools or is it a python script ?  Provide the exact name of this program with the extension (.exe or .py or whatever)
Offline xrazzed
« Reply #1317 on: July 19, 2024, 06:00:49 pm »
My bad. idk i saw people saying it works so i thought it will work for me.. im rookie. The flir install 2 programm is .exe
Online Bud
« Reply #1318 on: July 19, 2024, 06:21:17 pm »
You said "Flir install 2". Was that a typo?
Offline xrazzed
« Reply #1319 on: July 19, 2024, 06:23:44 pm »
when i open this app it shows Flir install 2 u can see screenshot
Online Bud
« Reply #1320 on: July 19, 2024, 06:53:46 pm »
Unzip the attachment and run the .CMD from that Flir Install application. Capture the log output.
Offline xrazzed
« Reply #1321 on: July 19, 2024, 07:01:38 pm »
As i understood its only can use .fif files
Online Bud
« Reply #1322 on: July 19, 2024, 07:03:51 pm »
Select the camera first in the top box
Edit: Actually I think you need to rename .zip to .fif , than run. Still need to select the camera.
« Last Edit: July 19, 2024, 07:05:40 pm by Bud »
Offline xrazzed
« Reply #1323 on: July 19, 2024, 07:05:41 pm »
the same :(
Offline xrazzed
« Reply #1324 on: July 19, 2024, 07:07:05 pm »
sorry, u mean .cmd to .fif?
Edit: also i dont really understand how to do this..
Edit 2: So another thing is that this FLIR app sees different IP or whats it idk look in screenshots..
Edit 3: I also have that "Remove_RNDIS_Permament" from the guide its .fif type
« Last Edit: July 19, 2024, 07:17:13 pm by xrazzed »
