Recently I got myself a FLIR E4 and with the information in this thread and
fubar.gr I managed to enable both the high resolution mode and the enhanced menu. Naturally I had seen seen before and after sample images but I was still blown away by the difference. It's like an entirely different tool. Many thanks to everyone who contributed in making this possible!
A few observations that may or may not help others:
FLIRInstallNet.exe recognized the E4 as "USB Video Device" (in non-RNDIS mode), not as "FLIR USB Video". FLIR Tools had no issues to communicate with the E4, though. I could see the firmware version and serial number in FLIR Tools. I tried in 32-bit Windows XP and 32-bit Windows 7 (both virtual machines) and the FLIR device drivers were installed. I even tried to manually update the drivers of the USB video device in Device Manager but that did not work. The E4 was never recognized as "FLIR USB Video" which got me worried but in the end it did not matter. I managed to apply the hack successfully.
I could not make FLIRInstallNet.exe run the *.fif files (button greyed out) until I actually switched on the E4. After hooking up the E4 to my computer, the battery charging screen appeared and it was recognized as a camera and storage device in Windows - so I assumed the connection was okay - but FLIRInstallNet.exe refused to run the *.fif files. It took me a while until I realized I had to switch on the E4. The instructions at
fubar.gr did not explicitly mention this, so maybe I did something wrong, but in the end everything worked.
My E4 came with firmware 2.8.0 which I had to downgrade to 2.3.0 first. I used the firmware package provided by matmoe earlier in this thread (
link). Upgrade (or rather downgrade) instructions are in the included PDF file - read it if you don't want to waste time figuring out how to install a custom firmware with FLIR Tools like I did.
Just like matmoe and facesnorth I have the impression that the E4 calibrates more often after downgrading firmware 2.8.0 to 2.3.0. I did not really time the intervals before the downgrade so I do not have hard numbers. Keep in mind that there is currently no way back to 2.8.0 if you don't like 2.3.0! Nevertheless, the benefit of having the high resolution mode and enhanced menu far outweighs the higher calibration frequency in my opinion. In fact it's not just the resolution that increases - the thermal sensitivity does as well (<0.15°C for the E4 against <0.06°C for the E8) and the noise levels are orders of magnitude lower. Subtle details are much easier to spot and something like a hand print on a wall was much, much longer visible after the hack than before.
The boot screen now shows "FLIR Special Edition" instead of just "FLIR". This change came with the enhanced menu hack ("2.3.0_Menu.fif" includes a new boot image). Fraser posted more details what the Special Edition entails (
link).
For reference, the temporalMk of my E4 (
requested by Solare):
.calib.nrdp.ds250C_we_ap_fi_le.measureInfo.temporalMk double 12.863767
Before and after thermal image (MSX disabled):
(pictures taken hours apart so the temperature differences between before and after may not be relevant, but just look at all the detail in the after picture)
