2 Navynuke:
So, after you updated your post, it is not that confusing, just to summarize:
- you used FlirTools old version (which exactly?) on Windows XP (which exactly SP?)
- you proceeded as described in the *.pdf found in the upgrade archive folder attached (2.3.0) step by step
- when succeed, you applied standard Fubar procedure to unlock your camera and it worked
This means, you effectively used FlirTools, but in some other way than 'upgrade camera' usual way.
Please confirm every line of this list above and provide the detailed info because people here might follow and get their cameras bricked (2 "bricked" reports so far against 2 "success" reports makes 50% chances for success!)
