@max-bit
@newbies
Reading all the Thread is a Nightmare.
Yet, you have to read it at least three times to get introductory understanding.
Either you are profi so you can adjust procedures according your needs (and your own responsibility)
Or you are a welcome guest; use whatever you found on your own risk, but follow the procedures LITERALLY.
Do not assume even a slightest difference will not matter.
It will
Do not assume people here have lots of spare time to guide you step-by-step recovering your bricked device...
Be carefull, be patient, do not hurry. Prepare your problem well. Make it attractive or even seductive for the users
Don't panic. After all, you will manage to achieve anything you want... after a while... mostly long while
Now...
@max-bit.
It seems you are using Google Translate or similar service... so really, it is difficult to understand you.
What is your native language then?
