and yet another 2.3 upgraded
Had similar issues as Swake. Started the upgrade on a Win7 Pro (64) (1 of 2). After running permanent.fif, ipconfig only showed 169.254.x.x, 255.255.0.0.
Second machine tried was Win 8.1 (64) ipconfig gave same results after again releasing and renewing, also went as far as killing ipv6 on both the 1st and 2nd machine.
Beginning to think it was bricked at this point.
Three hours later achieved success on the third machine Win7 Pro (64)(2 of 2). I did not kill ipv6. I did not install Flir Tools,
I only installed 32bit Flir drivers on this 3rd (64bit) machine. Ran ipconfig, after driver install, with 192.168.0.2 showing went right to Filezilla for immediate backup.
The res hack its..its....sooo pretty.
Many thanks to all participants of the discussion and EEVBlog.
This post is brought to you by the print button (above-right of the first post on each page) and (Ctrl)+(f).
