...had to add a little tweak to my e8.cfg...
Can you provide a cook book for that? Details, please!
PS: anybody knows what where the differences between HW releases 1.0, 1.1, and so on?
To start off - if your sticking with stock firmware and features and you already have a working e8.cfg on the camera - just flash the stock 2.3.0 FIF and your done - nothing else is needed - it just worked for me.
But if your going to use janekivi's menu's you need to go through your e8.cfg line by line and make sure that you have all the entries present that he lists in his conf_contents_requirements.txt.
I had tweaked mine many times in the past but was missing the block that had:
.caps.config.ui.image entry
.caps.config.ui.image.adjust entry
.caps.config.ui.image.adjust.enabled bool true
.caps.config.ui.image.adjust.manual bool true
in it - but yours may differ so it's best to check.
Once I added them I used the original CRC01 hack method to re-CRC it and uploaded the E8.cfg and rebooted.
No need to touch any DLL's, run .py scripts, or mess with encrypted cfg files.
As for the differences in 1.0/1.1/1.2 + L etc... I actually emailed support yesterday about it and they indicated that it's actually config not hardware revisions. I don't think anyone has torn down anything publicly other then mike's 1.0 and shared yet to prove otherwise.
