I run into trouble every time i try to install the new menu hack.
The FLIRInstall keeps saying that i don't have enough space? :
Received shell command message:
FLIR Command Line Interpreter
Version 0.4.3 running on WinCE 6.0
Connected
Installation started...
Adding /FlashBFS/system/arctic.pal
Failed to add /FlashBFS/system/arctic.pal - There is not enough space on the disk.
Adding /FlashBFS/system/lava.pal
Failed to add /FlashBFS/system/lava.pal - There is not enough space on the disk.
Adding /FlashBFS/system/rainhc.pal
Adding /FlashBFS/system/bootlogo_legal.bmp
Adding /FlashBFS/system/appcore.d/factory.d/ui_control.rsc
Failed to add /FlashBFS/system/appcore.d/factory.d/ui_control.rsc - There is not enough space on the disk.
Adding /FlashBFS/system/ui.d/presets.d/preset_centerspot.rsc
Adding /FlashBFS/system/ui.d/presets.d/preset_nomeasure.rsc
Adding /FlashBFS/system/ui.d/toolbar-config.xml
Adding /FlashBFS/system/ui.d/facet.rcc
Has anyone else bumped in to the same problem?
![Huh? ???](https://www.eevblog.com/forum/Smileys/default/huh.gif)
