Another 2.3.0/1.2L puppy just got converted here. Observations:
- in RNDIS mode the camera has a DHCP server with address 192.168.0.2 and will assign 192.168.0.1 to the computer
- Installing FLIR Tools does not install USB network (RNDIS) drivers. You can either install them as a separate package (search for flir_device_drivers.zip posted here before by someone) or as part of FLIR Player software (freeware from FLIR web site). Do this before trying to convert.
- not possible to set camera to RNDIS mode via camera's hidden menu. Has to be done using FLIRInstallNet.exe
- DHCP via RNDIS did not work on my Win7 64-bit. When I installed RNDIS drivers and uploaded Set_RNDIS_temporary.fif, the RNDIS driver recognized it and a new network adapter popped up in Windows Control Panel, but DHCP did not work and apparently the overall IP stack did not work, so that new adapter never gets the 192.168.0.1 address, and even if I could go and set it manually on that network adapter, still could not ping the camera or FTP to it. I then tried uploading Set_RNDIS_permament.fif and ended up with a semi-bricked camera in terms of the camera still worked but I could not connect to it anymore neither via USB nor via RNDIS
- uploading Set_RNDIS_permament.fif and rebooting the camera changed the camera mode in the camera hidden menu to RNDIS, but same as for USB the mode cannot be changed from the camera. My guess was I could only revert it to USB if I can connect to the camera via RNDIS and delete the file that was uploaded before. But how do I connect to it if DHCP did not work?
- the solution was to move to a Win XP machine. I have a Win XP virtual machine on my W7 x64. I installed the RNDIS drivers package there, redirected the USB port to the VM and bingo, a new network adapter popped up and a message popped up that camera found on 192.168.0.2
- from this point I was able to ftp to the camera and browse the filesystem, on the XP machine
- installed Python v2.x on the XP and ran the conversion script as per the instructions and rebooted the camera
Man, what a difference!
So do not know if Win7 32-bit would work, mine was 64-bit with the latest Windows Updates, did not work. XP seems to work OK.
As others reported, there is also http access to the camera via a browser, you get a information page with some statistics and version info.
