How to: Transfer images from a hacked 2.3 E4 to an IPad Air (iOS 8.1) via usb
Initially I purchased one of these:
Upon hooking up the Flir it gave me an error of:
"Cannot use device: the device uses too much power captain" (using your best Scottish accent)
At this point, figured there was not a way.
Then, I found this video which explains how you can use a non-powered usb hub in-between the adapter & camera cord to bypass the error.
Video:
http://youtu.be/J-I-nnocYtUFor my usb hub I bought one of these cheesy things at Walmart for $6.
For me it worked well except ONLY the thermal images transfer over vs the original & thermal.
Anyone know if that is a settings issue?In order to have the original photo transfer on to your ipad with the thermal, you must select on your camera:
Main menu
Save options
Photo as a separate JPEG > on
Perform a Reboot
This will allow you to import the photos from your camera roll to Flir Tools for Ipad and edit, notate and email from the ipad.
